Component: GSM (EB066, Generic AT) (Wireless)
| Author | Matrix Ltd. |
| Version | 1.3 (Release) |
| Category | Wireless |
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
GSM Example
The AT injector component allows us to simulate the response of the GSM module.
DialNumber
Performs a standard voice call by dialling the number specified.
Returns 0 for call in progress and 255 for no response.
- <- STRING Number
GetTextString
Collects the text message data from an incoming text message.
- BYTE NumBytes
SendScript
Send an AT command script.
Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
AnswerIncomingCall
Answers the phone for an incoming type call.
Returns 0 for success and 255 for failure.
SendCommand
Sends a command string to the GSM module.
0 = Command sent ok, 255 = No Reply
- <- STRING Command
- BYTE SendCR
GetTextNumber
Collects the sender's phone number from an incoming text message.
- BYTE NumBytes
HangUpCall
Ends a voice based call.
ReadString
Copies the data from the data string array to a local string variable
- BYTE NumBytes
SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol.
- <- STRING Number
- <- STRING Message
StringReceive
Attempts to receive a string from the GSM modem.
CheckNetworkStatus
Returns the state of the GSM network.
0 = Not connected, 1 = connected, 255 = no reply from GSM.
CheckForIncoming
Checks to see if any incoming phone call or SMS message.
0 = Nothing, 1 = Text Received, 2 = Phone Ringing
Sets up the GSM module.
Returns 0 for OK, 255 for no reply and 254 for command fail.
Simulation macro reference
Expect Echo
This property is of type True or false and can be referenced with the variable name expect_echo.
Sets if we expect an echo of any data we send out to the GSM modem.
Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
String Array Size
This property is of type Signed integer and can be referenced with the variable name string_size.
Amount of RAM memory to dedicate to receiving responces from the GSM
Message Array Size
This property is of type Signed integer and can be referenced with the variable name message_size.
Amount of RAM memory to dedicate to storing the last SMS message received by the GSM.
This property is of type Fixed list of ints and can be referenced with the variable name baud.
Theoretical number of digital bits that can be send or received a second.
Theoretical because it is unlikely you will be constantly sending or receiving data 100% of the time.
Flow Control
This property is of type True or false and can be referenced with the variable name flow_control.
When enabled adds two extra pins to help control the flow of data between the device and the remote device.
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name script_count.
Maximum number of scripts to store in the device's ROM
Script1
This property is of type Multiple lines of text and can be referenced with the variable name script1.
ASCII based AT command data stored in ROM and used when sending script 1
This property is of type Fixed list of ints and can be referenced with the variable name channel.
Onboard UART peripheral to use to perform serial commands.
Software mode not available as code currently requires hardware receive interrupt in order to work correctly.
TX Pin
This property is of type Single digital pin and can be referenced with the variable name tx_pin.
UART Transmit Pin
RX Pin
This property is of type Single digital pin and can be referenced with the variable name rx_pin.
UART Receive Pin
Textual label shown on the component I/O flasher
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
