Component: UART (RS232) (Comms: Interface)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Version 2.0 (Release)
Category Comms: Interface
Image UART (RS232) component
Low level routines for controlling or interacting with a standard asyncronous serial interface. On a microcontroller the interface will be the onboard UART which will need voltage level shifting using a max2323 to become RS232 compatible. See the EB015 RS232 E-block for details.
SendString
Sends out a string of bytes from the UART interface.
<- STRING Data
This parameter may be returned back to the caller
SendNumber
Sends out a number as an ASCII String from the UART interface.
<- LONG Number
SendChar
Sends out a single packet from the UART interface.
INT Char
ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
BYTE NewBaud
ReceiveString
Attempts to receive a string of bytes from the UART interface.
BYTE Timeout
BYTE NumBytes
STRING
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
This macro has no parameters
ReceiveChar
Attempts to receive a single packet from the UART interface.
INT Timeout
Time to wait for valid data before returning, 0=Dont wait, 255=Wait forever.
INT
Simulation macro reference
GetConsoleHandle
HANDLE
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
Onboard UART peripheral to use to perform serial commands.
Software mode available but not recommended for receive applications unless combined with a pin interrupt.
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
Theoretical number of digital bits that can be send or received a second.
Theoretical because it is unlikely you will be constantly sending or receiving data 100% of the time.
Data Bits
This property is of type Fixed list of ints and can be referenced with the variable name DBITS.
Number of data bits in each send/receive packet
Return Type
This property is of type Fixed list of ints and can be referenced with the variable name RETURN.
Specifies the way the receive function indicates a timeout.
8 Bit mode - Timeout is represented by the value 255.
16 Bit mode - Timeout is represented by the value 512 allowing the value 255 to represent valid data
Timeout Value
This property is of type Unsigned integer and can be referenced with the variable name ToutVal.
Value used by the receive macros to indicate a timeout.
Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name FLOWEN.
When enabled adds two extra pins to help control the flow of data between the device and the remote device.
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO.
When enabled automatically resends out any received data to help the remote device know that the data is getting through ok.
Most AT type modems (e.g. Bluetooth modules) will automatically echo back incoming data.
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
UART Transmit Pin
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
UART Receive Pin
Textual label shown on the component I/O flasher
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to COM port hardware or the the data injector components.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
Lists all the current injector components available on the user's panel
