Component: Modbus Master (Comms: System)
Revision as of 09:54, 21 March 2017 by BenR (talk | contribs)
Author Matrix Ltd.
Version 1.3 (Release)
Category Comms: System
Image Modbus Master component
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
Example to talk to a CT-2EA Modbus Electronic kWh Meter ModbusDemo Setup to communicate via Embedded UART1 or Simulated COM3
Console data generated by the working example running in the simulation and communicating via the COM port.
Addressing
Data Type Common name Starting address Modbus Coils Bits, binary values, flags 00001 Digital Inputs Binary inputs 10001 Analog Inputs Binary inputs 30001 Modbus Registers Analog values, variables 40001
ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount.
Returns 0 for success, 1 for CRC fail and 255 for no reply.
UINT SlaveID
The ID of the MODBUS slave
UINT RegAddress
Address: 0=40001, 1=40002, ...
UINT RegCount
Number of consecutive registers to read, starting from RegAddress
BYTE
ForceMultipleCoils
This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount.
UINT SlaveID
UINT CoilAddress
Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
UINT CoilCount
Number of consecutive coils to try and read
BYTE CoilData
An array of bytes each containing 8 1-bit coil values
BYTE
ForceSingleCoil
This command writes the contents of a discrete coil at the location CoilAddress.
UINT SlaveID
UINT CoilAddress
BYTE CoilState
0=Off, 1=On
BYTE
GetResponse
Collects as much incoming data as possible and stored into the response buffer. The number of bytes received will be stored into location 0 of the response buffer.
Return value indicates validity of incoming CRC. 0 = OK, 1 = CRC fail, 255 = No Data
This macro has no parameters
BYTE
ReadCoilStatus
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount.
UINT SlaveID
UINT CoilAddress
UINT CoilCount
BYTE
GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
BYTE Index
0=NumBytes, 1=SlaveAddress, 2=FunctionCode/ExceptionCode, .....
BYTE
ReadInputStatus
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount.
UINT SlaveID
UINT DataAddress
Input Address: 0=10001, 1=10002, 2=10003, ...
UINT DataCount
Number of consecutive inputs to read, starting from RegAddress
BYTE
PresetSingleRegister
This command writes the contents of a analogue output holding registerl at the location RegAddress.
UINT SlaveID
UINT RegAddress
UINT RegValue
Value to send to the selected register
BYTE
ReadInputRegister
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount.
UINT SlaveID
UINT RegAddress
UINT RegCount
BYTE
PresetMultipleRegisters
This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount .
UINT SlaveID
UINT RegAddress
UINT RegCount
Number of consecutive registers to write, starting from RegAddress
UINT RegValue
Array of values to send to the registers
BYTE
Starts up the UART to allow communications
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
UART channel to specify a software channel or an onboard hardware channel
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
UART transmit pin
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
UART receive pin
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
Data rate in bits per second
Bus
This property is of type Fixed list of ints and can be referenced with the variable name BusType.
Specifies the bus mode being used,
RS232 allows you to connect a single master node to a single slave node.
RS485 allows you to connect a single master node to multiple slave nodes.
Frame Type
This property is of type Fixed list of ints and can be referenced with the variable name FrameType.
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBufferSize.
Slave ID Bytes
This property is of type Unsigned integer and can be referenced with the variable name AddressBytes.
Silent Interval
This property is of type Unsigned integer and can be referenced with the variable name SilentInterval.
Configures how much time to wait after each master modbus command before another command can be sent.
A silent interval of 60ms minimum is required in order to guarentee successful reception of the next transmission.
0=No Delay
60 = 60mS - Default
Range : 0 - 65535
UART Receive Timeout
This property is of type Unsigned integer and can be referenced with the variable name RXTOUT.
Amount of time to wait before timing out when listening for a slave's response.
Range: 0 - 255.
0 = Don't Wait
1 - 254 = X ms
255 = Wait Forever
Receive Timeout Count
This property is of type Unsigned integer and can be referenced with the variable name TOUTCNT.
Number of timeouts in a row to wait for until we decide the slave is not responding or finished responding
to a message.
Range: 0 - 255
0 = First Timeout Only
1 = First Timeout + 1
2 = First Timeout + 2
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to COM port hardware or the the data injector components.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name COM_port.
COM port assigned to allow the simulation to communicate with actual Modbus hardware.
