Component: Thermistor Template (Sensors)
Revision as of 10:31, 9 May 2018 by BenR (talk | contribs) (XML import)
Author Matrix
Version 1.0 (Release)
Category Sensors
Image Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C. EBM003 Example
GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
This macro has no parameters
INT
GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
FLOAT
CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
UINT ADCValue
ADC Reading to be converted
INT
GetADCValue
Returns the Raw ADC value from the Analogue Channel
UINT
Simulation macro reference
SetChannel
Set the ADC Channel
INT ChannelID
SetTemperature
Simulation macro that sets the internal ADC value to the appropriate value for a given temperature. This allows all internal systems of the sensor to be simulated.
FLOAT Temperature
The temperature in C - restricted to -25 to +125 range
ADC Channel
This property is of type Single analog pin and can be referenced with the variable name CHANNEL.
The ADC channel to which the thermistor circuit is connected.
It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected
between the ADC pin and +V.
ADC Bit Resolution
This property is of type Unsigned integer and can be referenced with the variable name ADC_BITS.
Resistor Value
This property is of type Unsigned integer and can be referenced with the variable name RESISTOR.
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the
positive supply rail.
-25C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name M25.
Value in Ohms of the Thermistor at -25 deg C
0C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P0.
Value in Ohms of the Thermistor at 0 deg C
This property is of type Unsigned integer and can be referenced with the variable name P25.
Value in Ohms of the Thermistor at 25 deg C
50C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P50.
Value in Ohms of the Thermistor at 50 deg C
75C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P75.
Value in Ohms of the Thermistor at 75 deg C
100C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P100.
Value in Ohms of the Thermistor at 100 deg C
125C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P125.
Value in Ohms of the Thermistor at 125 deg C
