Component: Combo Board (EB083) (E-blocks 1)
Revision as of 14:50, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.0 (Release)
Category E-blocks 1
Image Combo Board (EB083) component
A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
The following files provide examples of how to use this component:
Arduino Mega 2560 & Combo Board
This blank project consists of the Matrix EB083 Combo Board connected to an Arduino Mega 2560.
Arduino Uno R3 & Combo Board
This blank project consists of the Matrix EB093 Combo Board connected to an Arduino Uno R3.
Note; Due to a limitation in the Arduino Uno hardware, portA6 & PortA7 are replicated from PortA5 in this template.
Clear
This macro has no parameters
PrintString
<- STRING Text
Enter the text or variable to print to the LCD
This parameter may be returned back to the caller
SetPort
Sets the state of a single port
BYTE Port
0 = PortA, 1 = PortB
BYTE Value
GetSwitchState
Reads the state of a single switch
BYTE Port
BYTE Switch
0 = SW0, 7 = SW7
BYTE
PrintAscii
BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
INT Number
RAMWrite
BYTE Index
Values 0 to 7
BYTE d0
BYTE d1
BYTE d2
BYTE d3
BYTE d4
BYTE d5
BYTE d6
BYTE d7
GetPort
Reads the state of a single port
BYTE Port
BYTE
ClearLine
BYTE Line
The line to clear, zero being the first (top) line of the display
Cursor
BYTE x
Set the cursor position in the X plane, 0 is the left most cell
BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Command
BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
ULONG Number
BOOL Format
0=Signed, 1=Unsigned
ScrollDisplay
BYTE Position
Holds the number of positions to shift the display
BYTE Direction
0 = left, 1 = right
SegShowDigit
Displays a digit on the 7-seg display
BYTE Digit
Which of the digits to change (0 - 3)
BYTE Value
The value to display (0 - 9)
BYTE DecimalPoint
Decides if the decimal point is lit
RawSend
Sends data to the LCD display
BYTE data
The data byte to send to the LCD
BOOL type
A boolean to indicate command type: true to write data, false to write a command
ReadAnalogAsByte
Reads one of the analogue components as an byte value
BYTE Channel
0 = LDR, 1 = POT
BYTE
ReadAnalogAsInt
Reads one of the analogue components as an Integer value
BYTE Channel
0 = LDR, 1 = POT
INT
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.
The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
BYTE SearchCharacter
Character to look for a replace
BYTE ReplacementCharacter
New character value to use in place of the search character.
Start
Startup routine required by the hardware device.
Automatically clears the display after initialising.
SetLEDState
Sets the state of a single LED
BYTE Port
BYTE LED
0 = LED0, 7 = LED7
BYTE State
Simulation macro reference
Pin A0
This property is of type Single digital pin and can be referenced with the variable name PinA0.
Pin A1
This property is of type Single digital pin and can be referenced with the variable name PinA1.
Pin A2
This property is of type Single digital pin and can be referenced with the variable name PinA2.
Pin A3
This property is of type Single digital pin and can be referenced with the variable name PinA3.
Pin A4
This property is of type Single digital pin and can be referenced with the variable name PinA4.
Pin A5
This property is of type Single digital pin and can be referenced with the variable name PinA5.
Pin A6
This property is of type Single digital pin and can be referenced with the variable name PinA6.
Pin A7
This property is of type Single digital pin and can be referenced with the variable name PinA7.
Pin B0
This property is of type Single digital pin and can be referenced with the variable name PinB0.
Pin B1
This property is of type Single digital pin and can be referenced with the variable name PinB1.
Pin B2
This property is of type Single digital pin and can be referenced with the variable name PinB2.
Pin B3
This property is of type Single digital pin and can be referenced with the variable name PinB3.
Pin B4
This property is of type Single digital pin and can be referenced with the variable name PinB4.
Pin B5
This property is of type Single digital pin and can be referenced with the variable name PinB5.
Pin B6
This property is of type Single digital pin and can be referenced with the variable name PinB6.
Pin B7
This property is of type Single digital pin and can be referenced with the variable name PinB7.
