Component: Gyroscope (EBM009) (EBM Modules)
| Version | 2.0 (Release) |
| Category | EBM Modules |
Gyroscope (EBM009) component
Interface to the L3G4200D three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
GetZ
Returns the previously sampled Z axis data
GetY
Returns the previously sampled Y axis data
GetX
Returns the previously sampled X axis data
SampleDevice
Reads the Axis data from the device. Returns 0 if successful
ReadRegister
Read the data byte at the given address of the device
- BYTE address
- address of the register to be read
WriteRegister
Writes the data byte to the given address of the device.
- BYTE address
- address of register to be written with data byte
- BYTE data
- data byte to be written to device register
Initialise the component.
Simulation macro reference
Output Data Rate
This property is of type Fixed list of ints and can be referenced with the variable name ODR.
Full Scale Selection
This property is of type Fixed list of ints and can be referenced with the variable name FSS.
Specifies the maximum angular speed which the sensor can measure in degrees per second
X Axis
This property is of type Fixed list of ints and can be referenced with the variable name XEN.
Y Axis
This property is of type Fixed list of ints and can be referenced with the variable name YEN.
Z Axis
This property is of type Fixed list of ints and can be referenced with the variable name ZEN.
This property is of type Line of text and can be referenced with the variable name label_text.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SDA Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::SDAPins.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
SCL Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::SCLPins.
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
Simulation Type
This property is of type Fixed list of ints and can be referenced with the variable name SimType.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
Selects if the component pin connections are automatically generated on the data recorder window or not.
Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion.
No: Do not show the pin signals on the data recorder window.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
