Component: LCD (BL0169) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
LCD component to drive the E-blocks 2 BL0169 LCD board. Provides a 4 x 20 character alphanumeric display.
Clear
PrintString
- <- STRING Text
- Enter the text or variable to print to the LCD
PrintAscii
- BYTE character
- Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
- Enter the number or variable to print to the LCD
RAMWrite
- BYTE Index
- Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
ClearLine
- BYTE Line
- The line to clear, zero being the first (top) line of the display
Cursor
- BYTE x
- Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
- Set the cursor position in the Y plane, 0 is the top most cell
Command
- BYTE instruction
- Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
- ULONG Number
- BOOL Format
- 0=Signed, 1=Unsigned
ScrollDisplay
- BYTE Position
- Holds the number of positions to shift the display
- BYTE Direction
- 0 = left, 1 = right
RawSend
Sends data to the LCD display
- BYTE data
- The data byte to send to the LCD
- BOOL type
- A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.
The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
- Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
- Character to look for a replace
- BYTE ReplacementCharacter
- New character value to use in place of the search character.
Start
Startup routine required by the hardware device.
Automatically clears the display after initialising.
Simulation macro reference
Data 0 (11 / 7)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_0.
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Data 1 (12 / 8)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_1.
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Data 2 (13 / 9)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_2.
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Data 3 (14 / 10)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_3.
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Register Select (4)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_RS.
Register Select Pin - Informs the display if a command or data is about to be sent.
Enable (6)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_E.
Enable pin - Used to synchronise data writes to the display
