Component: SPI Master (EB013) (E-blocks 1)
| Version | 2.0 (Release) |
| Category | E-blocks 1 |
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in. If the hardware SPI pins are in use or more SPI channels are required then there is also a software mode available. Has additional functions to work with the E-blocks EB013 SPI hardware.
SendString
Sends a string of bytes to the SPI bus
- <- STRING Str
NVMSendChar
Send a byte to the non-volatile memory device on the EB013 SPI E-block.
- ULONG Address
- NVM Address to write data to
- BYTE Data
- Data Byte to write to the sepected memory location
GetString
Attempts to read a string of bytes from the SPI bus.
- BYTE NumBytes
- BYTE Ch
DACSendChar
Send a byte to the digital to analogue converter (DAC) on the EB013 SPI E-block.
- BYTE Data
- Data byte to output using the DAC
SendChar
General purpose SPI send byte macro
- BYTE Char
NVMGetChar
Reads a byte from the non-volatile memory device on the EB013 SPI E-block.
- ULONG Address
- NVM Address to read data from
EnableFram
Enable the SPI RAM chip on the EB013 SPI E-block.
FramOutput
Send a value to the RAM on the EB013 SPI E-block.
- BYTE Char
DisableFram
Disable the SPI RAM chip on the EB013 SPI E-block.
GetChar
General purpose SPI get byte macro
UnInitialise
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O.
Activates the SPI peripheral and claims control over the I/O pins.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
DAC En
This property is of type Single digital pin and can be referenced with the variable name DAC_En.
DAC enable pin - only used with the EB013 SPI E-block
NVM En
This property is of type Single digital pin and can be referenced with the variable name NVM_En.
NVM enable pin - only used with the EB013 SPI E-block
Board Version
This property is of type Fixed list of ints and can be referenced with the variable name Version.
The Latest version of the E-block have a newer NVM IC which requires 3 address bytes instead of 2 address bytes.
If you find that the NVM is not responding to commands then try changing the version property to match the version of the E-block.
The version is written on the board as EB013-00-X where X is the version number.
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
Clock Phase
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CKE.
Clock Polarity
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CKP.
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::SMP.
Data bit read sample point
Label used to identify the component on the panel.
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
