Component: Webserver (WIZ810MJ) (Comms: Networking)
Revision as of 15:08, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Author Matrix Ltd.
Version 2.0 (Release)
Category Comms: Networking
Image Webserver (WIZ810MJ) component
Webserver component designed to work with the WIZ810MJ module from Wiznet, as used in the version 2 EB023 E-block and MIAC System Industrial Addon. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
SetOutValue
BYTE index
<- STRING value
This parameter may be returned back to the caller
GetInValue
BYTE index
STRING
CreateServerSocket
Creates a listening socket on the selected channel and port ready to accept incoming web page requests.
BYTE Channel
UINT Port
BYTE
CheckSocketActivity
Checks for activity on the server socket and serves out the webpages to any requesting parties.
This macro has no parameters
BYTE
Simulation macro reference
Max Pages
This property is of type Signed integer and can be referenced with the variable name max_pages.
Maximum number of pages we can serve using the embedded page type webserver.
Name Page 1
This property is of type Line of text and can be referenced with the variable name name1.
Name of HTML page 1 - index.htm is the default page that will be presented.
HTML Page 1
This property is of type Multiple lines of text and can be referenced with the variable name html1.
Embedded HTML code used for page 1
Name Page 2
This property is of type Line of text and can be referenced with the variable name name2.
Name of HTML page 2
HTML Page 2
This property is of type Multiple lines of text and can be referenced with the variable name html2.
Embedded HTML code used for page 2
Name Page 3
This property is of type Line of text and can be referenced with the variable name name3.
Name of HTML page 3
HTML Page 3
This property is of type Multiple lines of text and can be referenced with the variable name html3.
Embedded HTML code used for page 3
Name Page 4
This property is of type Line of text and can be referenced with the variable name name4.
Name of HTML page 4
HTML Page 4
This property is of type Multiple lines of text and can be referenced with the variable name html4.
Embedded HTML code used for page 4
MIAC Industrial Addon
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Int Pin
This property is of type Single digital pin and can be referenced with the variable name int_pin.
Interrupt pin connection on Wiznet module
Gateway0
This property is of type Signed integer and can be referenced with the variable name gateway0.
IP address of the gateway to the internet if applicable.
Gateway1
This property is of type Signed integer and can be referenced with the variable name gateway1.
Gateway2
This property is of type Signed integer and can be referenced with the variable name gateway2.
Gateway3
This property is of type Signed integer and can be referenced with the variable name gateway3.
Subnet0
This property is of type Signed integer and can be referenced with the variable name subnet0.
Subnet mask of the server - usually 255.255.255.0
Subnet1
This property is of type Signed integer and can be referenced with the variable name subnet1.
Subnet2
This property is of type Signed integer and can be referenced with the variable name subnet2.
Subnet3
This property is of type Signed integer and can be referenced with the variable name subnet3.
IP0
This property is of type Signed integer and can be referenced with the variable name ip0.
IP address of the server - usually 192.168.0.x or 192.168.1.x
IP1
This property is of type Signed integer and can be referenced with the variable name ip1.
IP2
This property is of type Signed integer and can be referenced with the variable name ip2.
IP3
This property is of type Signed integer and can be referenced with the variable name ip3.
MAC0
This property is of type Signed integer and can be referenced with the variable name mac0.
MAC address of the server
MAC1
This property is of type Signed integer and can be referenced with the variable name mac1.
MAC2
This property is of type Signed integer and can be referenced with the variable name mac2.
MAC3
This property is of type Signed integer and can be referenced with the variable name mac3.
MAC4
This property is of type Signed integer and can be referenced with the variable name mac4.
MAC5
This property is of type Signed integer and can be referenced with the variable name mac5.
Count
This property is of type Fixed list of ints and can be referenced with the variable name Outgoing_Count.
Length 0
This property is of type Unsigned integer and can be referenced with the variable name Out_Len_0.
Length 1
This property is of type Unsigned integer and can be referenced with the variable name Out_Len_1.
Length 2
This property is of type Unsigned integer and can be referenced with the variable name Out_Len_2.
Count
This property is of type Fixed list of ints and can be referenced with the variable name Incoming_Count.
Length 0
This property is of type Unsigned integer and can be referenced with the variable name In_Len_0.
Sim Type
This property is of type Fixed list of ints and can be referenced with the variable name SimType.
Decides how to perform the simulation of the component.
TCP IP - Communicates using the Windows TCP IP communications DLL
SPI / Injector - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
Network Interface
This property is of type Fixed list of ints and can be referenced with the variable name TCP_Base::interface.
List of network interfaces connected to the PC.
Sets which interface we are communicating via.
