Component: Switch (BL0145) (E-blocks 2)
Revision as of 14:27, 24 May 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category E-blocks 2
Image Switch (BL0145) component
A set of 8 push switches that can be connected to an E-blocks 2 upstream board via a port connector. Switches are wired in an active high configuration.
ReadState
Read the state of the switch at the given index.
BYTE Index
The switch to read the status of.
BOOL : Key state - true = on, false = off
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
BYTE Index
Index of the switch to wait for.
ReadAll
Reads all of the switches at once, returning a byte containing one bit per
switch.
This macro has no parameters
BYTE : One bit per switch in the array.
WaitUntilLow
BYTE Index
Simulation macro reference
Input Mode
This property is of type Fixed list of ints and can be referenced with the variable name port.
Choose how your switches are connected.
PORT = Single port byte for all switches - pins are allocated in sequence from pin 0 - X
Custom = Individual pin by pin connections
Port
This property is of type Digital port byte and can be referenced with the variable name PortByte.
