Component: GLCD (BL0139) (E-blocks 2)
Revision as of 14:39, 7 September 2018 by SamT (talk | contribs) (→Image GLCD (BL0139) component)
Version 1.0 (Release)
Category E-blocks 2
Graphical display component designed to work with the ST7567 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work Compatible with the EB2 BL0139 Downstream E-block.
On the mono GLCD you can se the foreground and background colours as either black or white, using the component macros corresponding to the setting of foreground or background. There are also macros which you can put into the program to print a string or a number on the GLCDs screen. You can also draw various shapes on the mono GLCD, such as a circle, an ellipse, a line or a rectangle using component macros.
Make sure the connections in flowcode are all in the correct port and pins, the port letter should be the same as the one which your mono GLCD is connected to on your E-blocks 2 upstream board.
INT Number
UINT X
UINT Y
BYTE Font
BYTE Transparent
DrawLine
BYTE X1
BYTE Y1
BYTE X2
BYTE Y2
Write_Data
BYTE data
Goto_XY
BYTE X
BYTE Y
Plot
BYTE X1
BYTE Y1
DrawEllipse
UINT X
UINT Y
UINT XRadius
UINT YRadius
BYTE Transparent
BYTE Solid
SetDisplayOrientation
BYTE Orientation
BPlot
BYTE X1
BYTE Y1
Print
<- STRING Str
This parameter may be returned back to the caller
UINT X1
UINT Y1
Y coordinate 0-31
BYTE Font
BYTE Transparent
ClearDisplay
This macro has no parameters
SetBackgroundColour
BYTE PixelColour
0=White, 1=Black
Write_Command
BYTE Command
DrawCircle
UINT X
UINT Y
UINT Radius
BYTE Transparent
BYTE Solid
SetForegroundColour
BYTE PixelColour
0=White, 1=Black
DrawRectangle
BYTE X1
BYTE Y1
BYTE X2
BYTE Y2
BYTE Transparent
BYTE Solid
Simulation macro reference
Pixel Height
This property is of type Signed integer and can be referenced with the variable name pixel_height.
Pixel Width
This property is of type Signed integer and can be referenced with the variable name pixel_width.
Monochrome
This property is of type True or false and can be referenced with the variable name monochrome.
Foreground Color
This property is of type Color picker and can be referenced with the variable name foreground_colour.
Background Color
This property is of type Color picker and can be referenced with the variable name background_colour.
Color Bit Depth
This property is of type Signed integer and can be referenced with the variable name colour_bit_depth.
Red Bit Depth
This property is of type Signed integer and can be referenced with the variable name red_bit_depth.
Green Bit Depth
This property is of type Signed integer and can be referenced with the variable name green_bit_depth.
Blue Bit Depth
This property is of type Signed integer and can be referenced with the variable name blue_bit_depth.
Data Pin
This property is of type Single digital pin and can be referenced with the variable name data_pin.
Clock Pin
This property is of type Single digital pin and can be referenced with the variable name clock_pin.
A0
This property is of type Single digital pin and can be referenced with the variable name a0_pin.
CS
This property is of type Single digital pin and can be referenced with the variable name chip_sel_pin.
Chip select pin
Reset
This property is of type Single digital pin and can be referenced with the variable name reset_pin.
Display Method
This property is of type Fixed list of ints and can be referenced with the variable name DisplayMethod.
Chooses which method to use when drawing to the gLCD component
The bitmap is the more common mode but may run slowly on some machines.
The point cloud should run faster but may use more memory.
LCDVersion
This property is of type Fixed list of ints and can be referenced with the variable name LCDVersion.
