Component: DAC (MCP48x1) (MCP48x1) (Analog Output)
Revision as of 10:00, 7 March 2019 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Analog Output
Image DAC (MCP48x1) (MCP48x1) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4801 (8-Bit), MCP4811 (10-Bit) and MCP4821 (12-Bit) devices.
SetOutput
Sets the output voltage of the DAC
8-Bit: Range 0-255
10-Bit: Range 0-1023
12-Bit: Range 0-4095
UINT DAC_Value
The value to output to the DAC
ControlPins
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
BOOL Shutdown
0 = Shutdown Device, 1 = Device Active
BOOL Latch
0 = Data output driven from DAC register, 1 = Data output locked
Disable
Disables the DAC output.
This macro has no parameters
Enable
Enables the DAC Output.
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
Simulation macro reference
DAC IC
This property is of type Fixed list of ints and can be referenced with the variable name DAC_IC.
Selects which DAC IC is connected and therefore the bit depth available.
Gain Option
This property is of type Fixed list of ints and can be referenced with the variable name GainOP.
Vref Voltage
This property is of type Floating point and can be referenced with the variable name VrefVol.
Steps
This property is of type Unsigned integer and can be referenced with the variable name Steps.
Number of discrete output states available from the DAC.
Control Bits
This property is of type Signed integer and can be referenced with the variable name BITS.
Resolution
This property is of type Line of text and can be referenced with the variable name Res.
Voltage Resolution
This property is of type Floating point and can be referenced with the variable name VoltRes.
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Use SHDN Pin
This property is of type True or false and can be referenced with the variable name UseSHDN.
Allows the SHDN pin to be driven from an output pin on the microcontroller.
If not used then tie the SHDN pin to VCC to allow the DAC to function.
Use LDAC Pin
This property is of type True or false and can be referenced with the variable name UseLDAC.
Allows the LDAC pin to be driven from an output pin on the microcontroller.
If not used then tie the LDAC pin to GND to allow the DAC to function.
DAC Output Scope Trace
This property is of type True or false and can be referenced with the variable name ScopeTraces.
SPI Scope Traces
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
SPI Console Data
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
