Component: DAC Quad (MCP4728) (MCP4728) (Analog Output)
Revision as of 10:00, 7 March 2019 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Analog Output
Image DAC Quad (MCP4728) (MCP4728) component
Component to drive a quad digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4728 (12-Bit) devices.
SetOutput
Sets the output voltage of the DAC
12-Bit: Range 0-4095
BYTE Channel
Range: 0-3 / 0=DAC Channel 0 / 1=DAC Channel 1 ...
UINT DAC_Value
The value to output to the DAC
ControlPins
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
BOOL Latch
0 = Data output driven from DAC register, 1 = Data output locked
SetInitialEEOutput
Stores a DAC value into EE memory to be used on power up.
BYTE Channel
UINT DAC_Value
Disable
Disables the DAC output.
BYTE Channel
Enable
Enables the DAC Output.
BYTE Channel
SetDeviceAddress
Writes a new device address into EE memory.
The use LDAC pin component property must be set to true and the LDAC pin should be unique for every MCP4728 device connected to the I2C bus.
BYTE OldAddress
Range: 0-7
BYTE NewAddress
Range: 0-7
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
This macro has no parameters
Simulation macro reference
Pull Down Option
This property is of type Fixed list of ints and can be referenced with the variable name PDOption.
VREF Option
This property is of type Fixed list of ints and can be referenced with the variable name VREFOPtion.
Gain Option
This property is of type Fixed list of ints and can be referenced with the variable name GainOP.
Vref Voltage
This property is of type Floating point and can be referenced with the variable name VrefVol.
Steps
This property is of type Unsigned integer and can be referenced with the variable name Steps.
Number of discrete output states available from the DAC.
Control Bits
This property is of type Signed integer and can be referenced with the variable name BITS.
Resolution
This property is of type Line of text and can be referenced with the variable name Res.
Voltage Resolution
This property is of type Floating point and can be referenced with the variable name VoltRes.
Device Address
This property is of type Fixed list of ints and can be referenced with the variable name DeviceAddress.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
Use LDAC Pin
This property is of type True or false and can be referenced with the variable name UseLDAC.
Allows the LDAC pin to be driven from an output pin on the microcontroller.
If not used then tie the LDAC pin to GND to allow the DAC to function.
DAC Output Scope Traces
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
Selects if the component pin connections are automatically generated on the data recorder window or not.
Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion.
No: Do not show the pin signals on the data recorder window.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
