Component: E block 2 Helper (E-blocks 2)
| Author | Matrix Ltd |
| Version | 1.1 (Release) |
| Category | E-blocks 2 |
A purely cosmetic component to help simplify E-block 2 connections without having to keep referring to the datasheets. Specify which E-block 2 board your using and the component will display the connections required.
This component does not contain any downloadable macros
Simulation macro reference
E-block ID
This property is of type Fixed list of ints and can be referenced with the variable name EB_ID.
E-block product ID
E-block Name
This property is of type Line of text and can be referenced with the variable name EB_Name.
Cosmetic name of the E-block to confirm you have the correct board.
Bit 0
This property is of type Line of text and can be referenced with the variable name bit0.
Port 1 Bit 0
Bit 1
This property is of type Line of text and can be referenced with the variable name bit1.
Port 1 Bit 1
Bit 2
This property is of type Line of text and can be referenced with the variable name bit2.
Port 1 Bit 2
Bit 3
This property is of type Line of text and can be referenced with the variable name bit3.
Port 1 Bit 3
Bit 4
This property is of type Line of text and can be referenced with the variable name bit4.
Port 1 Bit 4
Bit 5
This property is of type Line of text and can be referenced with the variable name bit5.
Port 1 Bit 5
Bit 6
This property is of type Line of text and can be referenced with the variable name bit6.
Port 1 Bit 6
Bit 7
This property is of type Line of text and can be referenced with the variable name bit7.
Port 1 Bit 7
Bit 0
This property is of type Line of text and can be referenced with the variable name bit8.
Port 2 Bit 0
Bit 1
This property is of type Line of text and can be referenced with the variable name bit9.
Port 2 Bit 1
Bit 2
This property is of type Line of text and can be referenced with the variable name bit10.
Port 2 Bit 2
Bit 3
This property is of type Line of text and can be referenced with the variable name bit11.
Port 2 Bit 3
Bit 4
This property is of type Line of text and can be referenced with the variable name bit12.
Port 2 Bit 4
Bit 5
This property is of type Line of text and can be referenced with the variable name bit13.
Port 2 Bit 5
Bit 6
This property is of type Line of text and can be referenced with the variable name bit14.
Port 2 Bit 6
Bit 7
This property is of type Line of text and can be referenced with the variable name bit15.
Port 2 Bit 7
