Component: BBC Weather Observation (Comms: IoT/Cloud)
Revision as of 15:31, 6 August 2019 by BenR (talk | contribs) (XML import)
Author MatrixTSL
Version 1.0 (Release)
Category Comms: IoT/Cloud
Image BBC Weather Observation component
Easily allows you to collect observed weather metrics for your area using the BBC Weather data service. Supports temperature and humidty for your selected area. Also available are Wind Direction, Wind Speed and Air Pressure but please note these are not always available depending on your selected area.
GetWindDirection
Reads the reported wind direction as a string.
Please note this data may not be available for your selected location.
This macro has no parameters
STRING
RequestData
Requests data about your selected location from the BBC weather service.
Returns true if the request was successful.
Must be called before trying to call any of the GetXXX macros.
BOOL : Returns true if the operation is a success, else false
GetHumidity
Reads the reported humidity in Relative Humdity.
BYTE
GetTemperature
Reads the reported temperature in the selected scale.
BOOL Scale
0 = Celcius, 1 = Farenheit
INT
GetWindSpeed
Reads the reported wind speed in MPH.
BYTE
SetLocationCode
Allows the location code to be altered from the default location code set in the component properties.
After changing the location the RequestData macro must be called to refresh the forecast variables.
<- STRING NewLocation
New location string, see Location property tooltip for more info.
This parameter may be returned back to the caller
GetPressure
Reads the reported air pressure in milli bar (mb).
UINT
GetLocationName
Reads the reported location name as a string.
STRING
Sets up the component ready to collect weather data.
Simulation macro reference
Network Comms Component
This property is of type Panel object and can be referenced with the variable name NetworkCommsComp.
Network Communications component to use as the bridge to the TCP/IP network.
BBC IP Address
This property is of type Line of text and can be referenced with the variable name IPAddr.
IP Address linked to the following URL: weather-broker-cdn.api.bbci.co.uk
Location Code
This property is of type Line of text and can be referenced with the variable name Location.
BBC code for your area.
In a web browser go to www.bbc.co.uk/weather/
Then type in your city in the search bar and your code will be shown at the end of the URL.
For example Manchester in the UK = 2643123
In the UK you can also use the first half of your post code, e.g. HX1
Receive Timeout
This property is of type Unsigned integer and can be referenced with the variable name RxTimeout.
Maximum time to wait for valid incoming data.
