Component: DAC (Internal) (Analog Output)
| Version | 2.0 (Release) |
| Category | Analog Output |
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
SetOutput
Sets the output voltage of the DAC
- UINT DAC_Value
- The value to output to the DAC
Disable
Disables the DAC output.
Enable
Enables the DAC Output.
Simulation macro reference
GetValue
Gets the Name property value
- STRING Name
- The name of the property
SetValue
Sets the Value for the named property
- STRING Name
- Name of property to update
- STRING Value
- The new value for the property
GetList
- STRING Name
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
DAC Channel number
DAC Output Pin
This property is of type Single digital pin and can be referenced with the variable name PORT.
DAC Output Pin
Vref Option
This property is of type Fixed list of ints and can be referenced with the variable name VREFOP.
Vref Voltage
This property is of type Floating point and can be referenced with the variable name VrefVol.
Control Bits
This property is of type Signed integer and can be referenced with the variable name BITS.
Resolution
This property is of type Line of text and can be referenced with the variable name Res.
Voltage Resolution
This property is of type Floating point and can be referenced with the variable name VoltRes.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
