Component: Digital Valve (Industrial)
Revision as of 09:46, 28 August 2019 by BenR (talk | contribs) (→Examples)
Version 1.0 (Release)
Category Industrial
Image Digital Valve component
A simple digital valve that can be either open or closed. The valve has component macros to set and get the current state of the valve. The valve can be initialised to be open or closed when starting. The valve can be clicked to open or close via the runtime. Compatible with SCADA interconnecting pipe components.
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
Industrial Tanks
This component does not contain any downloadable macros
Simulation macro reference
GetState
Returns the current state of the valve.
0 = Closed
1 = Open
This macro has no parameters
BOOL : Returns true if the operation is a success, else false
SetState
Sets the current state of the valve.
BOOL State
0 = Closed, 1 = Open
Default State
This property is of type Fixed list of ints and can be referenced with the variable name Default_State.
The initial state of the valve when the runtime starts
Current State
This property is of type Fixed list of ints and can be referenced with the variable name Current_State.
The current state of the valve.
Orientation
This property is of type Fixed list of ints and can be referenced with the variable name Orientation.
The orientation of the valve on the panel.
Clickable
This property is of type True or false and can be referenced with the variable name Clickable.
Dictates if the valve handle ca be clicked during runtime to open or close the valve,
Flip
This property is of type True or false and can be referenced with the variable name Flip.
