Component: 7Segment (Hex TM1637) (Segment)
Revision as of 12:03, 25 February 2020 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Segment
Image 7Segment (Hex TM1637) component
Hex seven segment display using an two pin communications bus to reduce the number of control pins. Also provides up to 16 individual input switches. Driven using a TM1637 hex 7-segment display driver.
ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
BYTE Value0
The number value to set the digit to (0...15), 16=Clear
BYTE Value1
BYTE Value2
BYTE Value3
BYTE Value4
BYTE Value5
BYTE DecimalPoint
Bit field containing the states of the decimal points.
ReadSwitches
Samples the switches and returns a value from 0-16.
0 indicates that no switches are pressed.
1 - 16 indicates that a switch is pressed and provides the index of the switch.
Only one switch can be pressed at any time.
This macro has no parameters
BYTE
SetBrightness
Controls the brightness of the 7-seg displays
BYTE Brightness
Range: 0-7 - 0=Darkest, 7=Brightest
BOOL On
0 = Display Off, 1 = Display On
ShowSegments
Allows for manual control over the display segments.
The colon character can also be controlled when writing to digit 1.
BYTE Digit
Which of the digits to change. (0...5)
BYTE Segments
The binary segment value to display
ShowDigit
Set the number to be displayed in the given digit of the display.
BYTE Digit
BYTE Value
BYTE DecimalPoint
Whether to show the decimal point.
Simulation macro reference
Display Type
This property is of type Fixed list of ints and can be referenced with the variable name Display_Type.
Set this according to the specification of your hardware display.
Common Anode: Pin true -> LED Off, Pin false -> LED On
Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
This property is of type True or false and can be referenced with the variable name ShowSegLabels.
Show segment name labels overlayed over the component.
DIO
This property is of type Single digital pin and can be referenced with the variable name DATA_PIN.
Data Pin connection to TM1637 IC
CLK
This property is of type Single digital pin and can be referenced with the variable name CLK_PIN.
Clock Pin connection to TM1637 IC
LED Color
This property is of type Color picker and can be referenced with the variable name FGColor.
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
This property is of type Color picker and can be referenced with the variable name BGColor.
Color of the plastic casing containing the LEDs.
Label Color
This property is of type Color picker and can be referenced with the variable name LabelColor.
Color for the optional LED segment labels.
