Component: Grey Code Encoder (General Input)
| Version | 1.4 (Release) |
| Category | General Input |
Grey Code Encoder component implements a rotary encoder connected to a defined number of pins Grey Code Encoders provide absolute positioning rather than incremental positioning.
ReadAbsoluteAngle
Reads the absolute angular position of the motor.
Returns a floating point value representing the angle of the encoder.
ReadAbsolutePosition
Returns an integer value representing the step position.
Simulation macro reference
Rotate
Simulation Rotate function to allow accurate rotation during simulation.
Automatically called by any attached coupling or gearbox component.
- FLOAT Angle
- Amount to rotate the shaft input in degrees
Output States
This property is of type Unsigned integer and can be referenced with the variable name OutputStates.
Number of unique output states
Resolution
This property is of type Floating point and can be referenced with the variable name Resolution.
The resolution of the encoder in degrees
Number of Pins
This property is of type Fixed list of ints and can be referenced with the variable name NumPins.
Sets the number of output pins on the encoder and hence the resolution of the encoder.
Pin0
This property is of type Single digital pin and can be referenced with the variable name pin_0.
Input pin 0
Pin1
This property is of type Single digital pin and can be referenced with the variable name pin_1.
Input Pin 1
Pin2
This property is of type Single digital pin and can be referenced with the variable name pin_2.
Input Pin 2
Repeat Rate
This property is of type Fixed list of ints and can be referenced with the variable name reprate.
Simulated repeat rate when clicking and rotating the encoder
This property is of type True or false and can be referenced with the variable name ScopeTraces.
