Component: RFID (BL0197) (E-blocks 2)
| Author | Matrix Ltd. |
| Version | 2.0 (Release) |
| Category | E-blocks 2 |
Low level routines for controlling a BL0197 RFID E-block 2 board. Complete with macros to control the tag type and buzzer parameters.
GetRFIDTypeID
Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module.
SetCardType
Allows the RFID tag type to be configured
- BYTE TagType
- 0 = MIFARE, 1 = ICODE, 2 = ISO14443B
WriteRFIDBlock
Writes a block of information to the RFID device.
- BYTE Address
- Remote RFID Block Address.
- BYTE Key_Type
WriteRFIDModule
Stores a byte of data to the internal EEPROM of the RFID module at the address specified.
- BYTE Address
- BYTE Data
DecrementRFIDValue
Perfoms a 32-bit decrement on the number held in location page or block.
- BYTE Src
- Page / Block
- BYTE Dst
- Page / Block
- BYTE Key_Type
- Needed for MIFARE Commands
FormatRFIDValue
Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command.
IncrementRFIDValue
Perfoms a 32-bit increment on the number held in location page or block.
- BYTE Src
- Page / Block
- BYTE Dst
- Page / Block
- BYTE Key_Type
StoreRFIDKey
Stores a 6 byte key for use with MIFARE type devices that require authorisation.
- BYTE Key
- Key Location 0 - 31
- BYTE D0
- Least significant byte of key
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
- Most significant byte of key
WriteRFIDBuffer
Writes a byte of data to the outgoing buffer.
- BYTE Address
- The address of the buffer 0 - 15
- BYTE Data
- The data to be stored in the buffer location 0 - 255.
GetRFIDStatus
Collect the status of the RFID device (see help for the explaination of the status byte).
ReadRFIDBuffer
Reads a byte of data from the incoming buffer.
- BYTE Address
TransferRFIDValue
Perfoms a 32-bit block data transfer on the number held in location page or block.
- BYTE Src
- Page / Block
- BYTE Dst
- Page / Block
- BYTE Key_Type
GetRFIDUID
Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module.
ReadRFIDUID
Reads a byte of data from the UID buffer.
- BYTE Address
- The address of the buffer 0 - 7
IsTagPresent
Checks to see if a card is present.
Returns 0 if no tag is present.
Returns 1 if a valid tag is present.
- BOOL : Returns true if the operation is a success, else false
SetBeep
Allows the buzzer output to be configured
- BYTE BeepDelay
- 0 = Off, 1 = 40mS, 2 = 80mS, 3 = 120mS etc.
ReadRFIDBlock
Reads a block of information from the RFID device.
- BYTE Address
- BYTE Key_Type
Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties.
Simulation macro reference
Card_Type
This property is of type Fixed list of ints and can be referenced with the variable name Card_Type.
Beep Delay
This property is of type Fixed list of ints and can be referenced with the variable name BeepDelay.
Amount of time to activate the buzzer when detecting a new RFID tag.
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart::BAUD.
TX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::TX.
RX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::RX.
Card Detect (LED)
This property is of type Single digital pin and can be referenced with the variable name CardDetect.
CTS
This property is of type Single digital pin and can be referenced with the variable name CTS.
This property is of type True or false and can be referenced with the variable name cal_uart::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
Simulation - draws an approximation of the UART data onto the scope trace.
ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name cal_uart::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name cal_uart::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::DataSource.
Simulation data source used to allow the component to connect to various remote devices
Nothing - Simulation data is ignored
COM port - Routes the communication data to and from a physical or virtual COM port
Injector - Routes the communication data via a data injector component on the Panel.
