Component: GLCD (ST7789V) (Graphical Color)
| Author | Matrix Ltd |
| Version | 1.6 (Release) |
| Category | Graphical Color |
Graphical display component designed to work with the ST7789V 16-bit colour graphical controller IC.
ReadFontWidth
- BYTE Font
- Font selection range: 0 to (NumFonts - 1)
- BYTE Character
- ASCII character to get the pixel width e.g. 'A' or 65
BacklightOn
Switches on the backlight
- INT Number
- Byte or Integer number to send to the display.
- UINT X
- X pixel coordinate to set the output string position.
- UINT Y
- Y pixel coordinate to set the output string position.
- BYTE Font
- Range: 0 to 31 - 0=5x8, 1=10x8, 2=10x16, 3=5x16, 4-31=Extended Sizes
- BYTE Transparent
- Specifies if the background of the text is drawn - 0 = Background colour is drawn, 1 = Background colour not drawn.
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Plot
- UINT X1
- UINT Y1
DrawEllipse
- UINT X
- X Coordinate for the center of the circle
- UINT Y
- Y coordinate for the center of the circle
- UINT XRadius
- Radius of the circle on the X axis specified in pixels
- UINT YRadius
- Radius of the circle on the Y axis specified in pixels
- BYTE Transparent
- 0=Fill inside circle using background colour / 1=Draw outer circle only
- BYTE Solid
- 0=Use Transparent Setting / 1=Fill with foreground colour
FastPlot
Sets a pixel with the current foreground colour at current pixel location.
Not compatible with orientations other than 0.
SetDisplayOrientation
- BYTE Orientation
- 0=Default, 1=90°CW, 2=180°CW, 3=270°CW
BacklightOff
Switches off the backlight
BPlot
- UINT X1
- UINT Y1
Window
Specifies a full screen or sub window of pixels to draw.
Useful when used with the FastPlot function to draw bitmaps at high speed.
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
ReadFontStat
- BYTE Font
- BYTE Index
- 0=SpaceWidth, 1=PixelHeight
- <- STRING Str
- String of characters to send to the display.
- UINT X1
- UINT Y1
- BYTE Font
- Selects which Font to use Range: 0 to Font Count
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
- 0 - 255 where 0 = no red and 255 = maximum red
- BYTE Green
- 0 - 255 where 0 = no green and 255 = maximum green
- BYTE Blue
- 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- Radius of the circle specified in pixels
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- Chooses the transparency of the box - 0 = Box contains background colour, 1 = Box contains previous pixel data.
- BYTE Solid
- Chooses to fill the box with colour - 0 = Box contains transparency data, 1 = Box contains foreground colour.
Simulation macro reference
Pixel Width
This property is of type Signed integer and can be referenced with the variable name pixel_width.
Pixel Height
This property is of type Signed integer and can be referenced with the variable name pixel_height.
X Offset
This property is of type Unsigned integer and can be referenced with the variable name XOffset.
Horizontal offset before the active display pixels.
Y Offset
This property is of type Unsigned integer and can be referenced with the variable name YOffset.
Vertical offset before the active display pixels.
Monochrome
This property is of type True or false and can be referenced with the variable name monochrome.
Foreground Color
This property is of type Color picker and can be referenced with the variable name foreground_colour.
Background Color
This property is of type Color picker and can be referenced with the variable name background_colour.
Invert Colours
This property is of type True or false and can be referenced with the variable name InvColours.
Colour Bit Depth
This property is of type Signed integer and can be referenced with the variable name colour_bit_depth.
Red Bit Depth
This property is of type Signed integer and can be referenced with the variable name red_bit_depth.
Green Bit Depth
This property is of type Signed integer and can be referenced with the variable name green_bit_depth.
Blue Bit Depth
This property is of type Signed integer and can be referenced with the variable name blue_bit_depth.
Data
This property is of type Single digital pin and can be referenced with the variable name data_pin.
Data pin connection
Clock
This property is of type Single digital pin and can be referenced with the variable name clock_pin.
Clock pin connection
Chip Select
This property is of type Single digital pin and can be referenced with the variable name chip_sel_pin.
Chip select pin connection
Reset
This property is of type Single digital pin and can be referenced with the variable name ResetPin.
Reset Pin
Backlight
This property is of type Single digital pin and can be referenced with the variable name BacklightPin.
Backlight Pin
Use DC Pin
This property is of type True or false and can be referenced with the variable name UseDC.
DC
This property is of type Single digital pin and can be referenced with the variable name DCPin.
Data/Command Pin
Font Count
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::FontCount.
Font
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font1::Font.
Character Spacing
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font1::FontSpace.
Sets the number of blank pixels between each character when printing text.
Default 1.
Space Width
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font1::SpaceWidth.
Font
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font2::Font.
Character Spacing
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font2::FontSpace.
Default 1.
Space Width
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font2::SpaceWidth.
Font
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font3::Font.
Character Spacing
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font3::FontSpace.
Default 1.
Space Width
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font3::SpaceWidth.
Font
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font4::Font.
Character Spacing
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font4::FontSpace.
Default 1.
Space Width
This property is of type Fixed list of ints and can be referenced with the variable name Base_GLCD::gLCD_Font4::SpaceWidth.
Display Method
This property is of type Fixed list of ints and can be referenced with the variable name DisplayMethod.
Chooses which method to use when drawing to the gLCD component
The bitmap is the more common mode but may run slowly on some machines.
The point cloud should run faster but may use more memory.
