Raspberry Pi MQTT Broker
Revision as of 20:48, 14 October 2020 by BenR (talk | contribs) (Created page with "==Initial Setup== Raspbery Pi running Noobs or Raspbian Linux. To install the Mosquitto Broker enter these next commands: sudo apt update sudo apt install -y mosquitto mo...")
Initial Setup
sudo apt update
sudo apt install -y mosquitto mosquitto-clients
You may have to type Y and press Enter to confirm the installation.
To make Mosquitto auto start on boot up enter:
mosquitto -v
This returns the Mosquitto version that is currently running in your Raspberry Pi. It should be 1.4.X or above.
Raspberry Pi IP Address
To use Mosquitto broker later on your projects, you’ll need your Raspberry Pi IP address. To retrieve your Raspberry Pi IP address, type the next command in your Terminal window:
hostname -I
Testing the Broker
Securing the Broker with a Username and Password
Encrypting the Broker
