Component: Console Writer (Indicators)
| Version | 1.0 (Release) |
| Category | Indicators |
Console Writer component
A simple component to aid in creating and wiriting data to a console tab. Allows text to be coloured and automatically appended with a timestamp.
This component does not contain any downloadable macros
Simulation macro reference
Clear
Clears the contents of the console tab.
CountLines
Counts the number of lines in the console.
AddString
Adds text string to the console window.
- <- STRING Data
SetTextLine
Sets the string data from a specific line in the console.
- LONG Line
- Line number, -1 for the last line.
- <- STRING Data
SetColour
Allows for full RGB colour selection
- BYTE R
- Colour channel, Range: 0-255
- BYTE G
- BYTE B
SetColourIdx
Sets the text colour from the properties selection of colours.
- BYTE Index
- Range: 0-3
GetTextLine
Gets the string data from a specific line in the console.
- LONG Line
Console Name
This property is of type Line of text and can be referenced with the variable name ConsoleName.
Colour 0
This property is of type Color picker and can be referenced with the variable name Colour0.
Colour 1
This property is of type Color picker and can be referenced with the variable name Colour1.
Colour 2
This property is of type Color picker and can be referenced with the variable name Colour2.
Colour 3
This property is of type Color picker and can be referenced with the variable name Colour3.
New Line After Data
This property is of type True or false and can be referenced with the variable name NLAfterData.
Clear On Sim Start
This property is of type True or false and can be referenced with the variable name ClearOnSimStart.
Automatically clear the console tab when the simulation is started.
Add Timestamp
This property is of type True or false and can be referenced with the variable name Timestamp.
Date Format
This property is of type Fixed list of ints and can be referenced with the variable name TimeStamp1::DateFormat.
Specifies the format of the date string.
No - "DD/MM/YY"
Yes - "MM/DD/YY"
Time Separator
This property is of type Line of text and can be referenced with the variable name TimeStamp1::TimeSeperator.
Characters that are used in between the time digits
Date Separator
This property is of type Line of text and can be referenced with the variable name TimeStamp1::DateSeparator.
Characters that are used in between the date digits
TimeStamp Separator
This property is of type Line of text and can be referenced with the variable name TimeStamp1::TimeStampSeparator.
Characters that are used between the time and date strings when returning a full time stamp.
Override Colour
This property is of type True or false and can be referenced with the variable name OverrideColour.
Overrides the current selected colour when writing the timestamp.
Timestamp Colour
This property is of type Color picker and can be referenced with the variable name TimestampColour.
