Command Buffer Size
Maximum number of bytes that can be stored in the outgoing command buffer.
Response Buffer Size
Maximum number of bytes that can be stored in the incoming response buffer.
Script Count
Controls how many AT scripts are stored into non-volatile memory
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
TX
RX
Use Flow Control
Flow Control (Handshake) enable or disable.
On: Two I/O pins are used to control the flow of data in and out of the device.
Off: Flow control is disabled.
Baud Options
