Component: ADC (MCP356X) (Analog Input)
| Author | MatrixTSL |
| Version | 1.0 (Release) |
| Category | Analog Input |
An external ADC featuring 2, 4, or 8 channel 24-bit input. Capable of reading each channel independently or in differential mode. Communication using an SPI bus up to 20MHz.
SampleADC
Performs a single ADC sample and returns the result as a 24-bit value
- BYTE PositiveChannel
- 0=CH0 - 7=CH7, 8=GND, 9=VDD, 11=REF+, 12=REF-, 13=TP, 14=TM, 15=VCM
- BYTE NegativeChannel
Confgures the SPI bus ready for communications and initialises the MCP356X device.
Returns true if device is responding to commands.
- BOOL : Returns true if the operation is a success, else false
Simulation macro reference
Device Type
This property is of type Fixed list of ints and can be referenced with the variable name DevType.
Device Address
This property is of type Fixed list of ints and can be referenced with the variable name DevAddress.
These bits are fixed from the manufacturer and by default are 01.
Used as Bits 6 and 7 of the command byte.
Alternative bits must be requested from the manufacturer.
Clock Selection
This property is of type Fixed list of ints and can be referenced with the variable name ClockSelection.
Sensor Bias Current
This property is of type Fixed list of ints and can be referenced with the variable name BiasCurrent.
ADC Bias Current
This property is of type Fixed list of ints and can be referenced with the variable name ADCBiasCurrent.
AMCLK Prescaler
This property is of type Fixed list of ints and can be referenced with the variable name Prescaler.
Oversampling Ratio
This property is of type Fixed list of ints and can be referenced with the variable name OversamplingRatio.
ADC Gain
This property is of type Fixed list of ints and can be referenced with the variable name ADCGain.
IRQ Mode
This property is of type Fixed list of ints and can be referenced with the variable name IRQMode.
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Use IRQ
This property is of type True or false and can be referenced with the variable name UseIRQ.
No: Use polling of the status register to determine when an ADC sample is complete.
Yes: Use the IRQ interrupt pin to determine when an ADC sample is complete.
IRQ Pin
This property is of type Single digital pin and can be referenced with the variable name IRQPin.
Connected to the IRQ pin of the device, goes low on an interrupt event such as sample complete.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimComms.
No: Simulation is done using panel sliders.
Yes: Send SPI data via API interface and show real time data using panel sliders.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
API
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
Selects the API Slave to use to send and receive real world SPI data during simulation.
