Component: DAC (Internal) (Analog Output)
| Version | 2.0 |
| Category | Analog Output |
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
| SetOutput | |
| Sets the output voltage of the DAC | |
| DAC_Value | |
| The value to output to the DAC | |
| GetValue | |
| Gets the Name property value | |
| Name | |
| The name of the property | |
| Disable | |
| Disables the DAC output. | |
| Enable | |
| Enables the DAC Output. | |
| SetValue | |
| Sets the Value for the named property | |
| Name | |
| Name of property to update | |
| Value | |
| The new value for the property | |
| GetList | |
| Name | |
| SetPivotPos | |
| Sets the position of the object the lever rotates around | |
| [[File:]] - | PositionHandle |
| A handle to the position of the depressed location | |
| SetLatching | |
| Sets whether the button is depressed when the mouse is released | |
| [[File:]] - | Enabled |
| Unregister | |
| Removes the object to the list if present | |
| [[File:]] - | Target |
| SetMovementFor | |
| Sets the movement in units or PI/16 steps for the button | |
| [[File:]] - | Move |
| Movement to set to, default 4 | |
| GetList | |
| Gets Named property List | |
| Name | |
| GetList | |
| returns Named property list | |
| Name | |
