Component: Slider control (Advanced Shapes)
Revision as of 16:14, 16 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category Advanced Shapes
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications. Meters
GetValue
Gets the current value of the slider. This will be within the range set by the SetRange macro.
[[File:]] - Return
SetValue
Set the current value of the slider. This will override any value set by using the mouse.
[[File:]] - Value
The value to set.
SetInteractive
Set whether the mouse can be used to change the slider value.
[[File:]] - Enable
Set true to allow clicks to set scale
ShowScale
Set whether graduated marking are shown along the length of the slider.
[[File:]] - Show
True to show scale, else false
SetRange
Set the minimum and maximum values that can be shown on the slider.
[[File:]] - Min
Min (start) value
[[File:]] - Max
Maximum (end) value
SetMarks
Decides on the presentation of the dial
[[File:]] - Marks
Number of marks on the dial
[[File:]] - Subs
Number of marks before a 'main' mark - can be zero
ClearArea
Clears the draw area
SetRange
Sets the min-max range to draw on the dial Used for setting the needle
[[File:]] - Start
[[File:]] - End
SetGaps
Sets the min-max of the span to draw on the X/Y marks Defaults are 0 and 1
[[File:]] - Start
[[File:]] - End
SetJustify
[[File:]] - RAlign
True for right/top/outer alignment
CalcAngle
Decide the angle to display at given a range value
[[File:]] - RangeVal
[[File:]] - Return
SetPivotPos
Sets the position of the object the lever rotates around
[[File:]] - PositionHandle
A handle to the position of the depressed location
SetAutoReset
Sets the state of the auto-reset flag If the flag is true (it is by default) then Button Helper will reset the state of each button on stop
[[File:]] - State
Set true to reset to off on sim stop, else false to retain state
SetLatching
Sets whether the button is depressed when the mouse is released
[[File:]] - Enabled
Unregister
Removes the object to the list if present
[[File:]] - Target
SetMovementFor
Sets the movement in units or PI/16 steps for the button
[[File:]] - Target
[[File:]] - Move
Movement to set to, default 4
Simulations
