Component: DSPBufferRef (DSP)
Revision as of 16:53, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category DSP
DSPBufferRef component
Reference and access to a specific DSP buffer inside another DSP component. Used for a DSP component input buffer.
Prv_PutPropStr
- UINT Idx
- UINT Val
Prv_PutConsole
- UINT Idx
- ULONG Val
get
- UINT Idx
[[File:]] - Return
put
- UINT Idx
[[File:]] - Val
Prv_GetPropStr
- UINT Idx
Prv_GetConsole
- UINT Idx
- ULONG Return
SetHandle
[[File:]] - Handle
IsPlaying
Checks to see if the last played track is still playing
[[File:]] - Return
GetReplyByte
Reads a single byte from the last reply. Each reply contains 4 bytes starting with the command code.
- BYTE Index
Range: 0-3 / 0=Command, 1=Feedback, 2=Data MSB, 3=Data LSB
SkipTrack
Jump to the next or previous track
[[File:]] - Direction
0=Next, 1=Previous
PlayTrack
Plays track from the selected folder. MP3 & Advert folder track numbers should be 4 characters long e.g. 0001 any name.mp3, Other folder track numbers should be 3 characters long e.g. 001 Any name.mp3, Root the Track played in placement order.
- BYTE Directory
0=Root, 1=Folder "01" - 99=Folder "99", 100=MP3, 101=Advert
- UINT Track
Track number 1="001*.MP3" / "0001*.MP3", 100="100*.MP3" / "0100*.MP3"
Sets up the UART and does some housekeeping. Must be called before calling any of the other component macros.
ReadAnalogAsInt
Reads one of the analogue components as an Integer value
- BYTE Channel
0 = LDR, 1 = POT
[[File:]] - Return
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
Character to look for a replace
- BYTE ReplacementCharacter
New character value to use in place of the search character.
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
SetLEDState
Sets the state of a single LED
- BYTE Port
0 = PortA, 1 = PortB
- BYTE LED
0 = LED0, 7 = LED7
- BYTE State
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Link To
Subname
Subhandle
Buffer Size
Buffer Type
Console Handle
Color
Outline
Text
Orientation
Simulations
