Component: Console Writer (Indicators)
| Category | Indicators |
Console Writer component
A simple component to aid in creating and wiriting data to a console tab. Allows text to be coloured and automatically appended with a timestamp.
| Clear | |
| Clears the contents of the console tab. | |
| CountLines | |
| Counts the number of lines in the console. | |
| AddString | |
| Adds text string to the console window. | |
| Data | |
| SetTextLine | |
| Sets the string data from a specific line in the console. | |
| [[File:]] - | Line |
| Line number, -1 for the last line. | |
| Data | |
| SetColour | |
| Allows for full RGB colour selection | |
| R | |
| Colour channel, Range: 0-255 | |
| G | |
| B | |
| SetColourIdx | |
| Sets the text colour from the properties selection of colours. | |
| Index | |
| Range: 0-3 | |
| GetTextLine | |
| Gets the string data from a specific line in the console. | |
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-1 | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| [[File:]] - | Last |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| ServoDisable | |
| Disable a Servo output | |
| Channel | |
| Range: 0-5 | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| ServoEnable | |
| Enable a Servo output | |
| Channel | |
| Range: 0-5 | |
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-5 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-17 | |
| [[File:]] - | State |
| Range: 0-1 | |
| ServoSetPosition8 | |
| Sets the position as an 8-bit value | |
| Channel | |
| Range: 0-1 | |
| Position | |
| Range: 0-255 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| WIFIGetIP | |
| Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active. | |
| I2CSend | |
| Channel | |
| DataOut | |
| [[File:]] - | Return |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Prescaler | |
| PWMSetDuty8 | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-1 | |
| Duty | |
| Range: 0-255 | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
