Component: Event Log (Runtime Tools)
| Category | Runtime Tools |
Event Log component
A simulation component designed to create a simple log record of events in your SCADA system. Logs to a file and / or to a console tab including optional automated time stamp.
| LogEvent | |
| Allows an event string to be logged | |
| LogString | |
| GetTextLine | |
| Gets the string data from a specific line in the console. | |
| [[File:]] - | Line |
| Line number, -1 for the last line. | |
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-1 | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| [[File:]] - | Last |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| ServoDisable | |
| Disable a Servo output | |
| Channel | |
| Range: 0-5 | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| ServoEnable | |
| Enable a Servo output | |
| Channel | |
| Range: 0-5 | |
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-5 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-17 | |
| [[File:]] - | State |
| Range: 0-1 | |
| ServoSetPosition8 | |
| Sets the position as an 8-bit value | |
| Channel | |
| Range: 0-1 | |
| Position | |
| Range: 0-255 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| WIFIGetIP | |
| Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active. | |
| I2CSend | |
| Channel | |
| DataOut | |
| [[File:]] - | Return |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Prescaler | |
| PWMSetDuty8 | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-1 | |
| Duty | |
| Range: 0-255 | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
