Component: Tone Generator (Runtime Tools)
Revision as of 20:43, 16 November 2021 by Wiki bot (talk | contribs)
Category Runtime Tools
Tone Generator component
A component to generate simple mono tone audio tones for use in alarms or other audible feedback.
PlayTone
Blocking call that plays a tone for a specific period of time.
- BYTE Tone
0=Off, 1=C, 2=C#, 3=D, 4=D#, 5=E, 5=F, 6=F#, 7=G, 8=G#, 9=A, 10=A#, 11=B, 12=C
- UINT Delay
delay in milliseconds
SetTone
Sets the output tone without blocking for the tone to end To end the note the macro must be called again with the tone paramete set to 0.
- BYTE Tone
ClearBuffer
Erases the contents of the buffer
ReadDigitalInputs
Reads the state of up to eight digital inputs. Can pack a max of 8-bits together in a single operation
- UINT StartAddress
Coil Address Range 0 to (NumCoils - 1)
- BYTE AddressCount
Range 1-8
GetLastIncoming
Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
SetAnalogInput
Sets the state of a single analogue input.
- UINT Address
Coil Address
- UINT Value
Analogue Value range 0 - 65535
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
AppendStringToFile
Adds the contents of the data string parameter to the end of the currently open file. Returns 0 for success.
- STRING Data_String
Data to append to the end of the file
ReadFileSize
Reads the entire size of the current file in bytes.
- ULONG Return
SetTimeAndDate
Sets the current time and date. Time = (Hour << 11) + (Min << 5) + (Sec >> 1) Date = (YearFrom1980 << 9) + (Month << 5) + (Day) Additional details can be found here: http://www.maverick-os.dk/FileSystemFormats/FAT16_FileSystem.html#TimeFormat
- UINT Time
Sets the current Time in FAT Time format hhhhhmmmmmmsssss - S=Secs/2
- UINT Date
Sets the current Date in FAT Date format yyyyyyymmmmddddd - Y=Years since 1980
Attempts to communicate with the SD card and if successful sets up the file system. Returns 0 for success.
Simulations
