Component: Digital Temperature (EBM004) (EBM Modules)
| Version | 2.0 |
| Category | EBM Modules |
Digital Temperature component
A digital temperature sensor based around the LM75B chip.
This example simply reads the value from the digital temperature sensor and outputs the value to an LCD as a temperature in degrees C.
| ReadInt | |
| Read double byte data from register at address | |
| address | |
| [[File:]] - | Return |
| ReadFloat | |
| Reads the temperature value as a float | |
| WriteByte | |
| address | |
| data | |
| WriteInt | |
| address | |
| data | |
| ReadByte | |
| Read a single byte at a specific address from the chip's internal memory. | |
| address | |
| Uninit | |
| Uninitialise and release resources | |
| Initialise to default of 11 bit resolution | |
| Initialise the sensor configuration as set by the component properties | |
| Stes up the I2C bus and initialises the termperature sensor ready for use. | |
| SimSetGyro | |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
| SimSetCompass | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
