| Author
| Version
1.0
| Category
Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Current
| [[File:]] -
GetTemperatureData
| Returns the raw register pair value
- UINT
GetTemperatureInt
| Return temperature reading as an integer value in degrees C
| [[File:]] -
GetHumidityInt
| returns the relative Humidity reading as an integer value
| [[File:]] -
GetHumidityReal
| returns the Humidity reading as a float value
| [[File:]] -
GetHumidityData
- UINT
| Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
- BYTE
Device
VDD
| Analogue Input Channel - Which pin is the analogue input connected to?
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Simulations
