Component: Thermistor (Environmental)
| Version | 1.1 |
| Category | Environmental |
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. Default calibration is for the EBM003 module.
| GetIntegerTemperature | |
| Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
| [[File:]] - | Return |
| SetChannel | |
| Set the ADC Channel | |
| [[File:]] - | ChannelID |
| SetMinMax | |
| Set the minimum and maximum temperature values that can be shown and set on the thermometer readout. | |
| [[File:]] - | Min |
| Minimum Value | |
| [[File:]] - | Max |
| Maximum Value | |
| GetRealTemperature | |
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
| CalculateTemperature | |
| Converts the input ADC value and returns the Temperature in tenths of degree C | |
| ADCValue | |
| ADC Reading to be converted | |
| GetADCValue | |
| Returns the Raw ADC value from the Analogue Channel | |
| Initialise to default of 11 bit resolution | |
| Configures each matching sensor on the bus with the specified conversion bits. | |
| WriteRegister | |
| A simple example showing a generic way to write a register using I2C. | |
| Address | |
| Data | |
