Component: USB MIDI (Comms: USB)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | Comms: USB |
USB MIDI component
Component to create and communicate using a standard MIDI connection. Compatible with simulation and USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
|   | SendPitchChange |
| Sends out a pitch change command on the specified channel. | |
|  - BYTE | Channel |
| Channel to send the pitch change to | |
|  - UINT | Pitch_Change |
| New pitch value to use, Default 0x2000 | |
|  - VOID | Return |
|   | SendNoteOff |
| Sends a note off command using the channel, note and velocity specified. | |
|  - BYTE | Channel |
|  - BYTE | Note |
|  - BYTE | Velocity |
|  - VOID | Return |
|   | SendControl |
| Sends a control command using the channel, controller and value specified. | |
|  - BYTE | Channel |
|  - BYTE | Controller |
|  - BYTE | Value |
|  - VOID | Return |
|   | SendNoteOn |
| Sends a note on command using the channel, note and velocity specified. | |
|  - BYTE | Channel |
|  - BYTE | Note |
|  - BYTE | Velocity |
|  - VOID | Return |
|   | SendPolyPressure |
| Sends a note press with an associated polyphonic pressure value. | |
|  - BYTE | Channel |
|  - BYTE | Note |
|  - BYTE | Pressure |
|  - VOID | Return |
|   | ReadData |
| Reads a byte from the last received MIDI message | |
|  - BYTE | Idx |
| Byte to read 0-3 | |
|  - BYTE | Return |
|   | SendPatch |
|  - BYTE | Channel |
|  - BYTE | Instrument |
|  - VOID | Return |
|   | SendChannelPressure |
|  - BYTE | Channel |
|  - BYTE | Pressure |
|  - VOID | Return |
|   | Initialise |
| Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout. | |
|  - BYTE | Return |
|   | OUTPUT |
| Sets the output to; 0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT. | |
|  - BYTE | SetOutput |
| Set the output. (0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT). | |
|  - VOID | Return |
|   | MODPWMDEVWDT |
| Sets the PWM waveform deviation to <nrf> sec. | |
| [[File:]] - | Sec |
|  - VOID | Return |
|   | SWPMODE |
| Sets the sweep mode to <CONT> or <TRIG>. 0 = CONT, 1 = TRIG. | |
| [[File:]] - | Mode |
| Set the sweep mode (0 = CONT, 1 = TRIG). | |
|  - VOID | Return |
|   | MODFSKRATE |
| Sets FSK rate to <nrf> Hz. (Lower limit: 2mHz - Upper limit: 100kHz). | |
| [[File:]] - | Rate |
| Sets FSK rate in Hertz(Hz) (2mHz - 100kHz). | |
|  - VOID | Return |
|   | BST |
| Sets the burst mode to; 0 = <OFF>, 1 = <NCYC>, 2= <GATED>, 3 = <INFINITE>. | |
|  - BYTE | MODE |
| Sets the burst mode (0 = OFF, 1 = NCYC, 2 = GATED, 3 = INFINITE). | |
|  - VOID | Return |
|   | LOLVL |
| Sets the amplitude-low-level to <nrf> Volts. (Lower limit: 5.000 V - Upper limit: -0.010 V). | |
| [[File:]] - | LowLevel |
| Sets the amplitude-low-level in Volts(V) (-5.000 V - -0.010 V). | |
|  - VOID | Return |
|   | SAV |
| Saves the complete instrument setup to the setup-file named <nrf> | |
|  - BYTE | StoreLocation |
| Memory location of register (0-9) | |
|  - VOID | Return |
|   | TRG |
| This command is the same as pressing the TRIGGER key. | |
|  - VOID | Return |
|   | ARBDCOFFS |
| Sets the arbritary dc waveform offset to <nrf> volts. | |
| [[File:]] - | OffsetVoltage |
| Set the offset voltage | |
|  - VOID | Return |
|   | SWPTRGPOL |
| Sets the sweep trigger slope to; 0 = POS, 1 = NEG. | |
| [[File:]] - | Slope |
| Set the sweep trigger slope (0 = POS, 1 = NEG). | |
|  - VOID | Return |
|   | CLKSRC |
| Sets the clock source to; 0 = INT, 1 = EXT. | |
| [[File:]] - | Source |
| Sets the clock source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | ARB1DEFRet |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1. | |
|  - STRING | Return |
|   | BEEP |
| Sound one beep. | |
|  - VOID | Return |
|   | SWPCNTFREQ |
| Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz). | |
| [[File:]] - | Frequency |
| Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz). | |
|  - VOID | Return |
|   | SWP |
| Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
| [[File:]] - | Sweep |
| Enable or disable the sweep (0 = ON, 1 = OFF). | |
|  - VOID | Return |
|   | BSTTRGSRC |
| Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN. | |
|  - BYTE | Source |
| Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN). | |
|  - VOID | Return |
|   | MODPWMFREQ |
| Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
|  - VOID | Return |
|   | ARB2Ret |
| Returns the binary-data from an existing abbitrary wavefrom memory location. | |
|  - UINT | Return |
|   | RST |
| Resets the instrument parameters to their default values. | |
|  - VOID | Return |
|   | RMPSYMM |
| Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100) | |
| [[File:]] - | Symmetry |
| Sets the ramp waveform symmetry in percent (0 - 100). | |
|  - VOID | Return |
|   | BSTCOUNT |
| Sets the burst count to <nrf> cycles, maximum 1048575 cycles. | |
| [[File:]] - | Count |
| Sets the burst count in cycles (1 - 1048575). | |
|  - VOID | Return |
|   | SWPMKR |
| Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
| [[File:]] - | Marker |
| Enable or disable the sweep marker (0 = ON, 1 = OFF). | |
|  - VOID | Return |
|   | PULSFREQ |
| Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz). | |
| Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz). | |
|  - VOID | Return |
|   | MODFMDEV |
| Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz). | |
| [[File:]] - | Deviation |
| Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz). | |
|  - VOID | Return |
|   | RCL |
| Recalls the instrument setup contained in store <nrf>. | |
| Memory location (0-9) | |
|  - VOID | Return |
|   | ESESet |
| Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255) | |
|  - BYTE | Value |
| Enable the register to this value. (0 - 255) | |
|  - VOID | Return |
|   | LOCAL |
| Returns the instrument to local opertion and unlocks the keyboard. | |
|  - VOID | Return |
|   | SWPSPNFREQ |
| Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz). | |
| Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz). | |
|  - VOID | Return |
|   | CALSTEP |
| Step to the next calibration point. | |
|  - VOID | Return |
|   | SRERet |
| Returns the value of the Service Request Enable Register in <nr1> numeric format. | |
|  - BYTE | Return |
|   | MODPMFREQ |
| Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
|  - VOID | Return |
|   | ARBRESIZE |
| Changes the size of arbritary waveform <cpd> to <nrf>. | |
| [[File:]] - | Size |
| Size of waveform | |
|  - STRING | Waveform |
| Arbritary Waveform | |
|  - VOID | Return |
|   | LRN |
| Intall data from a previous *LRN? command. | |
|  - VOID | Return |
|   | ARB4 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB4. | |
|  - BYTE | Waveform |
|  - VOID | Return |
|   | CLKSRRet |
| Returns the clock source <INT> or <EXT>. | |
| [[File:]] - | Return |
|   | MODPMDEV |
| Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°). | |
| [[File:]] - | Degrees |
| Sets PM waveform deviation in degrees (-360 - 360). | |
|  - VOID | Return |
|   | MSTLOCK |
| Sends signal to SLAVE generator to get synchronised | |
|  - VOID | Return |
|   | HILVL |
| Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V). | |
| [[File:]] - | HighLevel |
| Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V). | |
|  - VOID | Return |
|   | ARB3 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB3. | |
|  - UINT | Waveform |
|  - VOID | Return |
|   | CALADJ |
| Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100). | |
| [[File:]] - | Calibrate |
| Adjust the selected calibration value (-100 - 100). | |
|  - VOID | Return |
|   | STBRet |
| Returns the value of the Status Byte Register in <nr1> numeric format. | |
|  - BYTE | Return |
|   | ARB2 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB2. | |
|  - UINT | Waveform |
|  - VOID | Return |
|   | EERRet |
| Query and clear execution error number register. | |
|  - STRING | Return |
|   | MODFMSRC |
| Sets FM waveform source to; 0 INT, 1 = EXT. | |
| Sets FM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MODAMFREQ |
| Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
|  - VOID | Return |
|   | ESE |
| Sets the Standard Event Status Enable Register to the value of <nrf>. | |
|  - BYTE | Value |
| Value of register 0-255 | |
|  - VOID | Return |
|   | ARB1 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB1. | |
|  - UINT | Waveform |
| 16 Bit binary number for arbitrary waveform. | |
|  - VOID | Return |
|   | ARB4DEFRet |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4. | |
|  - STRING | Return |
|   | CLS |
| Clears status byte register of the interface. | |
|  - VOID | Return |
|   | MSTRELOCK |
| Resynchronises the two generators in MASTER-SLAVE mode. | |
|  - VOID | Return |
|   | NOISLVL |
| Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%) | |
|  - BYTE | Percent |
| Sets the output noise level in percent. (0 - 50) | |
|  - VOID | Return |
|   | LOCKMODE |
| Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP. | |
|  - BYTE | Mode |
| Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP). | |
|  - VOID | Return |
|   | ADDRESSRet |
| Returns the instruments address | |
|   | MODPMSRC |
| Sets PM waveform source to; 0 INT, 1 = EXT. | |
| Sets PM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MODPWMSRC |
| Sets PWM waveform source to; 0 = INT, 1 = EXT. | |
| Sets PWM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MOD |
| Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM. | |
|  - BYTE | Modulation |
| Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM). | |
|  - VOID | Return |
|   | ISTRet |
| Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
|   | LRNRet |
| Returns the complete setup of the instrument as a binary data block | |
|   | OPCRet |
| Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
|   | PULSRANGE |
| Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3. | |
|  - BYTE | Range |
| Sets the pulse rise and fall range. (1, 2 or 3) | |
|  - VOID | Return |
|   | TSTRet |
| The generator has no self test capability and the response is always 0 <rmt>. | |
|   | BSTTRGPOL |
| Sets the burst trigger slope to; 0 = POS, 1 = NEG. | |
| Set the burst trigger slope (0 = POS, 1 = NEG). | |
|  - VOID | Return |
|   | ARB3Ret |
|  - UINT | Return |
|   | BSTPHASE |
| Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360) | |
| Sets the burst phase in degrees (-360 - 360) | |
|  - VOID | Return |
|   | SWPTRGPER |
| Sets the sweep trigger period to <nrf> seconds | |
| [[File:]] - | Seconds |
| Set the sweep trigger period in seconds. | |
|  - VOID | Return |
|   | PULSDLY |
| Sets the waveform delay to <nrf> sec | |
| [[File:]] - | Sec |
|  - VOID | Return |
|   | Initialise |
| Opens the COM port ready for communications. | |
|  - VOID | Return |
