Component: Webserver (WIZ810MJ) (Comms: Networking)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | Comms: Networking |
Webserver component
Webserver component designed to work with the WIZ810MJ module from Wiznet, as used in the version 2 EB023 E-block and MIAC System Industrial Addon. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
|   | WM_CH_MR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_PORT |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_TXMEM |
|  - BYTE | ch |
|  - UINT | Return |
|   | MIAC_Module_SetData |
|  - BYTE | Count |
|  - BYTE | D0 |
|  - BYTE | D1 |
|  - BYTE | D2 |
|  - BYTE | D3 |
|  - BYTE | D4 |
|  - BYTE | D5 |
|  - VOID | Return |
|   | WM_CH_RX_RSR |
|  - BYTE | ch |
|  - UINT | Return |
|   | MIAC_Module_GetData |
|  - BYTE | Index |
|  - BYTE | Return |
|   | SetOutValue |
| Set the value of an outbound substitution string | |
|  - BYTE | index |
|  - STRING | value |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page4 |
|  - VOID | Return |
|   | MIAC_Module_Message |
|  - UINT | CAN_ID |
|  - UINT | CMD_ID |
|  - BYTE | Return |
|   | Send_Embedded_HTML_Page3 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page2 |
|  - VOID | Return |
|   | WM_CH_IR |
|  - BYTE | ch |
|  - UINT | Return |
|   | Send_Embedded_HTML_Page1 |
|  - VOID | Return |
|   | GetInValue |
| Returns the string value of a Request parameter | |
|  - BYTE | index |
|  - STRING | Return |
|   | MIAC_Module_PushData |
|  - BYTE | Data |
|  - VOID | Return |
|   | CreateServerSocket |
| Creates a listening socket on the selected channel and port ready to accept incoming web page requests. | |
|  - BYTE | Channel |
|  - UINT | Port |
|  - BYTE | Return |
|   | WM_CH_CR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_TX_WR |
|  - BYTE | ch |
|  - UINT | Return |
|   | IncRxPtr |
|  - BYTE | Channel |
|  - VOID | Return |
|   | CheckSocketActivity |
| Checks for activity on the server socket and serves out the webpages to any requesting parties. | |
|  - BYTE | Return |
|   | WM_CH_SR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_RXMEM |
|  - BYTE | ch |
|  - UINT | Return |
|   | ARB4 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB4. | |
|  - BYTE | Waveform |
|  - VOID | Return |
|   | CLKSRRet |
| Returns the clock source <INT> or <EXT>. | |
| [[File:]] - | Return |
|   | MODPMDEV |
| Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°). | |
| [[File:]] - | Degrees |
| Sets PM waveform deviation in degrees (-360 - 360). | |
|  - VOID | Return |
|   | MSTLOCK |
| Sends signal to SLAVE generator to get synchronised | |
|  - VOID | Return |
|   | HILVL |
| Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V). | |
| [[File:]] - | HighLevel |
| Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V). | |
|  - VOID | Return |
|   | ARB3 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB3. | |
|  - UINT | Waveform |
|  - VOID | Return |
|   | CALADJ |
| Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100). | |
| [[File:]] - | Calibrate |
| Adjust the selected calibration value (-100 - 100). | |
|  - VOID | Return |
|   | STBRet |
| Returns the value of the Status Byte Register in <nr1> numeric format. | |
|  - BYTE | Return |
|   | ARB2 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB2. | |
|  - UINT | Waveform |
|  - VOID | Return |
|   | EERRet |
| Query and clear execution error number register. | |
|  - STRING | Return |
|   | MODFMSRC |
| Sets FM waveform source to; 0 INT, 1 = EXT. | |
| [[File:]] - | Source |
| Sets FM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MODAMFREQ |
| Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| [[File:]] - | Frequency |
| Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
|  - VOID | Return |
|   | ESE |
| Sets the Standard Event Status Enable Register to the value of <nrf>. | |
|  - BYTE | Value |
| Value of register 0-255 | |
|  - VOID | Return |
|   | ARB1 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB1. | |
|  - UINT | Waveform |
| 16 Bit binary number for arbitrary waveform. | |
|  - VOID | Return |
|   | ARB4DEFRet |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4. | |
|  - STRING | Return |
|   | CLS |
| Clears status byte register of the interface. | |
|  - VOID | Return |
|   | MSTRELOCK |
| Resynchronises the two generators in MASTER-SLAVE mode. | |
|  - VOID | Return |
|   | NOISLVL |
| Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%) | |
|  - BYTE | Percent |
| Sets the output noise level in percent. (0 - 50) | |
|  - VOID | Return |
|   | LOCKMODE |
| Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP. | |
|  - BYTE | Mode |
| Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP). | |
|  - VOID | Return |
|   | ADDRESSRet |
| Returns the instruments address | |
|   | MODPMSRC |
| Sets PM waveform source to; 0 INT, 1 = EXT. | |
| Sets PM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MODPWMSRC |
| Sets PWM waveform source to; 0 = INT, 1 = EXT. | |
| Sets PWM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MOD |
| Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM. | |
|  - BYTE | Modulation |
| Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM). | |
|  - VOID | Return |
|   | ISTRet |
| Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
|   | LRNRet |
| Returns the complete setup of the instrument as a binary data block | |
|   | OPCRet |
| Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
|   | PULSRANGE |
| Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3. | |
|  - BYTE | Range |
| Sets the pulse rise and fall range. (1, 2 or 3) | |
|  - VOID | Return |
|   | TSTRet |
| The generator has no self test capability and the response is always 0 <rmt>. | |
|   | BSTTRGPOL |
| Sets the burst trigger slope to; 0 = POS, 1 = NEG. | |
| [[File:]] - | Slope |
| Set the burst trigger slope (0 = POS, 1 = NEG). | |
|  - VOID | Return |
|   | ARB3Ret |
| Returns the binary-data from an existing abbitrary wavefrom memory location. | |
|  - UINT | Return |
|   | BSTPHASE |
| Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360) | |
| Sets the burst phase in degrees (-360 - 360) | |
|  - VOID | Return |
|   | SWPTRGPER |
| Sets the sweep trigger period to <nrf> seconds | |
| [[File:]] - | Seconds |
| Set the sweep trigger period in seconds. | |
|  - VOID | Return |
|   | PULSDLY |
| Sets the waveform delay to <nrf> sec | |
| [[File:]] - | Sec |
|  - VOID | Return |
|   | Initialise |
| Opens the COM port ready for communications. | |
|  - VOID | Return |
