Component: ADC (AD7680) (Analog Input)
Revision as of 20:59, 16 November 2021 by Wiki bot (talk | contribs)
Category Analog Input
ADC (AD7680) component
16-bit external ADC connected to the microcontroller using SPI.
Overview
The AD7680 is a 2.5V to 5.5V SPI compatible, successive approximation analogue to digital converter (ADC).
The reference for the AD7680 is taken internally from VDD
Pin reference from the datasheet:
This example reads the voltage on the AD7680 Vin and converts the ADC results into a voltage. For the result to be correct, you must change the Voltage variable to match the supply voltage.
FC6 Icon.png AD7680 Demo
Circuit Diagram
Fc9-comp-macro.png SampleADC
Reads the ADC and returns the reading as an unsigned 16-bit value. Range: 0-65535 / 0=0V / 65535=VCC
Fc9-comp-macro.png Initialise
Initialise the SPI bus ready for communications,
Fc9-comp-macro.png NodeWake
Wakes up the local Zigbee module from sleep mode.
Fc9-comp-macro.png ReadATResponse
Reads a single byte from the received AT command response.
Fc9-u8-icon.png - BYTE idx
Specified the byte index in the buffer. Range 0-15
Fc9-comp-macro.png ScanBuffer
Returns a binary list of matched identifier names
Fc9-string-icon.png - STRING Compare_Str
Fc9-u8-icon.png - BYTE Length
Fc9-comp-macro.png SendChar
Transmits a byte value to the Zigbee module.
Fc9-u8-icon.png - BYTE Byte
Data byte to transmit. Range 0-255
Fc9-comp-macro.png InitNetwork
Initialises the Zigbee module and attempts to setup or join the network
Fc9-comp-macro.png ConnectToCoordinator
Attempts to connect the data channel to the network coordinator node.
Fc9-comp-macro.png MIAC_Module_GetData
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png ConnectToName
Attempts to connect the data channel to a named device on the network.
Fc9-string-icon.png - STRING Name
Fc9-comp-macro.png StoreParams
Stores the current register set into the Zigbee module's non volatile memory
Fc9-comp-macro.png EnterCommandMode
Moves from data mode into command mode by sending the special characters
Fc9-comp-macro.png RestartNetwork
Attempts to restart the network
Fc9-comp-macro.png MIAC_Module_Message
Fc9-u16-icon.png - UINT CAN_ID
Fc9-u16-icon.png - UINT CMD_ID
Fc9-comp-macro.png ConnectToAll
Attempts to connect the data channel to all devices on the network.
Fc9-comp-macro.png ConnectFromLibrary
Attempts to connect the data channel to a known device on the network.
Fc9-u8-icon.png - BYTE Mode
Fc9-u8-icon.png - BYTE Device
Fc9-comp-macro.png ConnectToAddress
Attempts to connect the data channel to a specific device address on the network.
Fc9-string-icon.png - STRING Address
Fc9-comp-macro.png GetSignalLevel
Returns the signal strength of the last signal received
Fc9-comp-macro.png ExitCommandMode
Returns from command mode to allow data to be sent and received
Fc9-comp-macro.png MIAC_Module_PushData
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png ReadAddressFromBuffer
Reads a byte from a 16-bit Zigbee device address
Fc9-u8-icon.png - BYTE Idx
Fc9-comp-macro.png SendATCommand
Transmits a string of values to the Zigbee module.
Fc9-string-icon.png - STRING Command
Transmits a command to the Zigbee module followed by a carriage return
Fc9-comp-macro.png ScanNetwork
Scans the local network for devices and stores into a local device array. Mode = 0 store device names, mode = 1 store device addresses. Returns the number of devices found.
Fc9-comp-macro.png GetATResponse
Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply.
Fc9-u8-icon.png - BYTE Logging
Fc9-comp-macro.png ReceiveChar
Attempt to receive a byte from the Zigbee module.
Fc9-u8-icon.png - BYTE nTimeout
Fc9-comp-macro.png MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Fc9-u8-icon.png - BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Fc9-comp-macro.png ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
Fc9-u8-icon.png - BYTE Waveform
Fc9-comp-macro.png CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
Fc9-comp-macro.png MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
Fc9-comp-macro.png MSTLOCK
Sends signal to SLAVE generator to get synchronised
Fc9-comp-macro.png HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
Fc9-comp-macro.png ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
Fc9-u16-icon.png - UINT Waveform
Fc9-comp-macro.png WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
Fc9-u8-icon.png - BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
Fc9-comp-macro.png CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
Fc9-comp-macro.png STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
Fc9-comp-macro.png ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
Fc9-comp-macro.png EERRet
Query and clear execution error number register.
Fc9-comp-macro.png MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] - Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
Fc9-comp-macro.png ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
Fc9-u8-icon.png - BYTE Value
Value of register 0-255
Fc9-comp-macro.png ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
16 Bit binary number for arbitrary waveform.
Fc9-comp-macro.png ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
Fc9-comp-macro.png CLS
Clears status byte register of the interface.
Fc9-comp-macro.png MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
Fc9-comp-macro.png NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
Fc9-u8-icon.png - BYTE Percent
Sets the output noise level in percent. (0 - 50)
Fc9-comp-macro.png LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
Fc9-comp-macro.png ADDRESSRet
Returns the instruments address
[[File:]] - Return
Fc9-comp-macro.png MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
Fc9-u8-icon.png - BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
Fc9-comp-macro.png ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
Fc9-comp-macro.png LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
Fc9-comp-macro.png OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
Fc9-comp-macro.png SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
Fc9-u8-icon.png - BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
Fc9-comp-macro.png PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
Fc9-u8-icon.png - BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
Fc9-comp-macro.png TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
Fc9-comp-macro.png BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
Fc9-comp-macro.png ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
Fc9-comp-macro.png BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
Fc9-comp-macro.png IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
Fc9-string-icon.png - STRING ReturnIDN
Fc9-comp-macro.png SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
Fc9-comp-macro.png PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Opens the COM port ready for communications.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Data Recorder Trace
