Component: DAC (MCP49x1) (Analog Output)
| Category | Analog Output |
DAC component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4901 (8-Bit), MCP4911 (10-Bit) and MCP4921 (12-Bit) devices.
| SetOutput | |
| Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095 | |
| DAC_Value | |
| The value to output to the DAC | |
| Disable | |
| Disables the DAC output. | |
| Enable | |
| Enables the DAC Output. | |
| Channel | |
| 0=DAC Channel 0 , 1=DAC Channel 1 | |
| Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
| WriteLEDs | |
| Allows control of all 8-LEDs on the front of the Formula Flowcode. | |
| LED_Byte | |
| Starts up the formula flowcode PWM for motor control and performs the wait for button press | |
