Component: RGB LED LP5030 LP5036 (LEDs)
Revision as of 21:08, 16 November 2021 by Wiki bot (talk | contribs)
Category LEDs
RGB LED LP5030 LP5036 component
An I2C Based RGB LED driver with 30 or 36 individual constant-current sinks. Used to drive 10 or 12 RGB LEDs with a wide range of applications.
GetRGB
Gets the RGB colour of a single LED.
- BYTE Address
Range: 0-11
- BYTE RGB
Byte array containing at least 3 bytes to store Red, Green and Blue
SetBrightness
Allows the brightness of a single LED to be specified as a byte from 0 to 255. Default on reset is 255.
- BYTE Address
Range: 0-11
- BYTE Brightness
Brightness value: Range 0-255
ReadReg
Reads the data from one or more sequential registers
- BYTE Address
- BYTE Data
- BYTE Count
WriteReg
Writes data to one or more sequential registers
- BYTE Address
- BYTE Data
- BYTE Count
SetRGB
Allows the colour of a single LED to be specified in RGB.
- BYTE Address
Range: 0-11
- BYTE RGB
Byte array containing at least 3 bytes to set Red, Green and Blue
GetBrightness
Gets the brightness of a single LED.
- BYTE Address
Range: 0-11
- BYTE RGB
SetUnitAddress
Allows the component to taklk to more then one IC or broadcast to all connected ICs.
- BYTE Address
Range: 0-3 = Individual / 4 = Broadcast
Starts up the I2C comms ready for communicating with the LP503x module. Must be called before any of the other component macros are called.
Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
ShiftLEDs1D
Shifts the LED colours in 1D and wraps
- BYTE Direction
0 = Forwards, 1 = Backwards
- BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
DrawLine3D
Draws a line on a 3D array of LEDs
- UINT X1
Start X Coordinate
- UINT Y1
Start Y Coordinate
- UINT Z1
Start Z Coordinate
- UINT X2
End X Coordinate
- UINT Y2
End Y Coordinate
- UINT Z2
End Z Coordinate
- BYTE R
Red Colour Channel
- BYTE G
Green Colour Channel
- BYTE B
Blue Colour Channel
Delay_T1H
GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
- UINT X
LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE R
- BYTE G
- BYTE B
ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
[[File:]] - X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
[[File:]] - Y
- BYTE DataMode
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
- UINT X
- UINT Y
- UINT Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
- BYTE X1
Start X pixel coordinate
- BYTE Y1
Start Y pixel coordinate
- BYTE Z1
Start Z pixel coordinate
- BYTE X2
End X pixel coordinate
- BYTE Y2
End Y pixel coordinate
- BYTE Z2
End Z pixel coordinate
- BYTE DrawStyle
- BYTE R
Red Colour Channel
- BYTE G
- BYTE B
White Colour Channel
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
- BYTE DataMode
Sets up the data memory and draws the simulated LED cube on the panel.
Driver IC
Address Pins
API
Specifies the API component on the panel to interact with to provide comms simulation.
Channel selection
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulations
Simulate Comms
