| Author
Matrix TSL
| Version
1.0
| Category
Analog Output
Digital Potentiometer (MCP44XX) component
The MCP44XX device range supports 4 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
IncrementWiper
| Increments a single volatile wiper value
- BYTE
Index
| Range: 0-3
DecrementWiper
| Decrements a single volatile wiper value
- BYTE
Index
| Range: 0-3
SetWiper
| Sets the value of a single wiper
- BYTE
Index
| Range: 0-3
- UINT
Value
| 129 Taps Range: 0-128 / 257 Taps Range: 0-256
| [[File:]] -
MemoryType
| 0=Volatile, 1=Nonvolatile
ReadAddress
| Reads a value from one of the registers on the device
- BYTE
Address
| Range: 0-15
- UINT
WriteAddress
| Writes a value to one of the registers on the device
- BYTE
Address
| Range: 0-15
- UINT
Value
| Range: 0-256
| Startup the I2C peripheral ready for communications.
| Starts up the I2C comms ready for communicating with the LP503x module. Must be called before any of the other component macros are called.
Refresh
| Clocks out the current colour data to the LEDs from the values stored in RAM
ShiftLEDs1D
| Shifts the LED colours in 1D and wraps
- BYTE
Direction
| 0 = Forwards, 1 = Backwards
- BYTE
DataMode
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
DrawLine3D
| Draws a line on a 3D array of LEDs
- UINT
X1
| Start X Coordinate
- UINT
Y1
| Start Y Coordinate
- UINT
Z1
| Start Z Coordinate
- UINT
X2
| End X Coordinate
- UINT
Y2
| End Y Coordinate
- UINT
Z2
| End Z Coordinate
- BYTE
R
| Red Colour Channel
- BYTE
G
| Green Colour Channel
- BYTE
B
| Blue Colour Channel
Delay_T1H
GetLEDIndex2D
| Sets the index of a single LED in RAM as a 2D array.
- UINT
X
| LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
| LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
DrawRectangle2D
| Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
| [[File:]] -
X
| Number of pixels to shift the display -1 to 1 / 0 = No Shift
| [[File:]] -
Y
- BYTE
DataMode
GetLEDIndex3D
| Gets the index of a single LED in RAM as a 3D array.
- UINT
X
- UINT
Y
- UINT
Z
| LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
| Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
| Start X pixel coordinate
- BYTE
Y1
| Start Y pixel coordinate
- BYTE
Z1
| Start Z pixel coordinate
- BYTE
X2
| End X pixel coordinate
- BYTE
Y2
| End Y pixel coordinate
- BYTE
Z2
| End Z pixel coordinate
- BYTE
DrawStyle
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| White Colour Channel
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
| [[File:]] -
X
| [[File:]] -
Y
| [[File:]] -
Z
- BYTE
DataMode
| Sets up the data memory and draws the simulated LED cube on the panel.
| Channel selection
SDA
SCL
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
Number of Taps
Address Bits
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the injector component on the panel to interact with to provide comms simulation.
Simulations
Simulate Comms
