| Category | Audio Output |
Piezo Sounder component
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. To actually drive a piezo you may have to amplify the signal from the microcontroller using a transistor or MOSFET.
Here is a simple example that will create a siren effect using a piezo sounder.
 Piezo Siren
Depending on your Piezo Sounder you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
Piezo Siren
|   | BuzzerBeep |
| Switches the buzzer on and off automatically to allow for a series of beeps |
|  - UINT | OnTime |
| Length of time in ms the buzzer will remain on |
|  - UINT | OffTime |
| Length of time in ms the buzzer will remain off |
|  - BYTE | NumberLoops |
| Number of times to repeat the sequence. Range 1-255 |
|  - UINT | Frequency |
| frequency in hz to output to the Piezo sounder |
|  - VOID | Return |
|   | BuzzerOnDelay |
| Switch the Buzzer on for a fixed amount of time |
|  - UINT | Time |
| Time in milliseconds to keep the buzzer on |
| Frequency to output in Hz |
|  - VOID | Return |
|   | SetAddress |
| Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules. |
|  - BYTE | Address |
| Range: 0x40 - 0x7F |
|  - VOID | Return |
|   | SetClockFrequency |
| Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty. |
|  - ULONG | Clock |
|  - VOID | Return |
|   | GetClockFrequency |
| Returns the current clock frequency |
|  - ULONG | Return |
|   | WriteMicroseconds |
| Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise |
|  - BYTE | Output |
| One of the PWM output pins - Range: 0 to 15 |
|  - UINT | Microseconds |
| The number of Microseconds to turn the PWM output ON |
|  - VOID | Return |
|   | SetPWM |
| Sets the PWM output of one of the PCA9685 pins |
|  - BYTE | Output |
|  - UINT | On |
| At what point in the 4096-part cycle to turn the PWM output ON |
|  - UINT | Off |
| At what point in the 4096-part cycle to turn the PWM output OFF |
|  - VOID | Return |
|   | Initialise |
| Sets up the I2C ready for communications to begin |
|  - VOID | Return |
|   | WakeUp |
| Wakes the module from Sleep mode |
|  - VOID | Return |
|   | SetPin |
| Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on. |
|  - BYTE | Output |
|  - UINT | Duty |
| The number of ticks out of 4096 to be active |
| [[File:]] - | Invert |
| 0=Normal, 1=Inverted |
|  - VOID | Return |
|   | DrawRectangle2D |
| Draws a basic 2D rectangle onto the LEDs |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - BYTE | X2 |
|  - BYTE | Y2 |
|  - BYTE | DrawStyle |
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | ShiftLEDs2D |
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable*** |
| [[File:]] - | X |
| Number of pixels to shift the display -1 to 1 / 0 = No Shift |
| [[File:]] - | Y |
|  - BYTE | DataMode |
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear |
|  - VOID | Return |
|   | GetLEDIndex3D |
| Gets the index of a single LED in RAM as a 3D array. |
|  - UINT | X |
| LED Column to change the colour / Range: 0 to (LED Column - 1) |
|  - UINT | Y |
| LED Row to change the colour / Range: 0 to (LED Row - 1) |
|  - UINT | Z |
| LED Layer to change the colour / Range: 0 to (LED Layer - 1) |
|  - UINT | Return |
|   | DrawCuboid3D |
| Draws a basic 3D cuboid onto the LEDs |
|  - BYTE | X1 |
| Start X pixel coordinate |
|  - BYTE | Y1 |
| Start Y pixel coordinate |
|  - BYTE | Z1 |
| Start Z pixel coordinate |
|  - BYTE | X2 |
| End X pixel coordinate |
|  - BYTE | Y2 |
| End Y pixel coordinate |
|  - BYTE | Z2 |
| End Z pixel coordinate |
|  - BYTE | R |
| Red Colour Channel |
|  - BYTE | G |
| Green Colour Channel |
|  - BYTE | B |
| White Colour Channel |
|  - VOID | Return |
|   | Initialise |
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to  initialise all the LED ICs in the chain. |
|  - VOID | Return |
|   | ShiftLEDs3D |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
|  - BYTE | DataMode |
|  - VOID | Return |
|   | Initialise |
| Sets up the data memory and draws the simulated LED cube on the panel. |
|  - VOID | Return |
|   | Properties |
|   | Output Pin |
| Pin used to drive the output to the buzzer |
|   | Color |
| Controls the color of the Buzzer object on the panel. |
|   | Connections |
|   | Simulations |
