Component: Image (2D Shapes)
Jump to navigationJump to search| Author | Steve Tandy |
| Category | 2D Shapes |
Image component
A basic image component for the 2d panel.
| GetValue | |
| Reads Named property Value. | |
| Name | |
| Slave_Init | |
| Initialise the Slave | |
| Master_Disable_CS | |
| Outputs a high signal to the chip select pin to deselect the remote slave device. | |
| Master_Uninit | |
| Uninitialise the Master | |
| Master_Byte | |
| Sends and receives a data byte | |
| DataOut | |
| GetConsoleHandle | |
| Returns a handle to the console used by this component | |
| [[File:]] - | Return |
| Slave_TxByte | |
| Sets the data to be transmitted to the SPI master. | |
| Data | |
| Slave_RxByte | |
| Returns the data received from the SPI Master | |
| SetValue | |
| Change Named property to new Value. | |
| Name | |
| Value | |
| SetPrescaler | |
| Sets the prescaler value for the clock divider chain | |
| Prescaler | |
| Master_Init | |
| Initialise the Master | |
| GetList | |
| returns Named property list | |
| Name | |
| Properties | |
| Image | |
| Filename | |
| Vertical Alignment | |
| Horizontal Alignment | |
| Connections | |
| Simulations | |
