Component: Panel Console Viewer (Runtime Tools)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Runtime Tools |
Panel Console Viewer component
An easy way to display the data from up to four console windows on the panel.
|   | SetText |
| Allows the selected text to be specified. | |
|  - BYTE | Item |
| 0=Title, 1=Col1, 2=Col2, 3=Col3, 4=Col4 | |
|  - STRING | Text |
|  - VOID | Return |
|   | GetText |
| Allows the selected text to be read back. | |
|  - BYTE | Item |
|  - STRING | Return |
|   | AssignConsoleHandle |
| Assigns a specific console handle to one of the text fields. | |
|  - BYTE | Item |
| [[File:]] - | ConsoleHandle |
|  - VOID | Return |
|   | SetColor |
| Sets the selected item's color. | |
|  - BYTE | Item |
| 0=Title, 1=Col1, 2=Col2, 3=Col3, 4=Col4, 5=Border | |
|  - ULONG | Color |
|  - VOID | Return |
|   | GetOffset |
|  - UINT | Return |
|   | ReceiveString |
| Gets a string from the receive buffer | |
|  - UINT | MaxChars |
|  - UINT | Timeout |
| Time in milliseconds to wait for data | |
|  - STRING | Return |
|   | Initialise |
| Initialises the UART component pins ready to send and receive data | |
|  - VOID | Return |
|   | Start |
| Startup routine required by the hardware device. Automatically clears the display after initialising. | |
|  - VOID | Return |
|   | SetLEDState |
| Sets the state of a single LED | |
|  - BYTE | Port |
| 0 = PortA, 1 = PortB | |
|  - BYTE | LED |
| 0 = LED0, 7 = LED7 | |
|  - BYTE | State |
|  - VOID | Return |
|   | GetRxIdent |
| Gets the Rx ID as a Integer Standard and Extended IDs. | |
|  - BYTE | Buffer |
|  - ULONG | Return |
|   | Initialise |
| Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
|  - VOID | Return |
