Component: Injector (COM) (Test Injectors)
Revision as of 10:36, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Test Injectors
Injector (COM) component
Comms data injector to allow a COM port peripheral to be attached to a comms component. The component will forward any outgoing bytes to the COM port and forward any incoming bytes to the comms component. Useful for controlling hardware such as Bluetooth, RS232, USB to Serial, MODBUS...
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
GetConsoleHandle
[[File:]] - Return
UARTReceive
- BYTE Channel
UARTSend
- BYTE Channel
- BYTE Data
AddInt
Int to add to the int array
- ULONG Value
AddFloat
Add a float to the floating point LUT
[[File:]] - Value
Floating point values
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
SampleAccel
Samples the accelerometer 0 = no new data, 1 = new data available
Left
Rotates the robot left - waits for the angle to be traversed before returning
- UINT Angle
Angle to turn in degrees
ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
- BYTE index
LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
- BYTE X
X Pixel 0-127
- BYTE Y
Y Pixel 0-31
- BYTE State
0=White (Off), 1=Black (On)
ServoSetPosition
Allows one of the servo positions to be assigned
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
CardBitmap
Displays a monochrome bitmap read from the card on the LCD
- BYTE X
Range 0-127
- BYTE Y
Range 0-31
- STRING Filename
CardRecordMic
Records an audio stream on the card from the microphone
- BYTE BitDepth
0=8-bit, 1=16-bit
- BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
- UINT RecordTime
Time to record for in seconds, Range 0-65535
- STRING Filename
CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
- STRING Filename
Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
GetConsoleHandle
[[File:]] - Return
LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
- BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
LCDBacklight
Allows the LCD backlight brighntess to be adjusted
- BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
LCDDrawRect
Allows a rectangle to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
- BYTE index
0=Left, 1=Right
ServoDisable
Allows one of the servo outputs 0-3 to be disabled
- BYTE Channel
Range 0-3
ServoEnable
Allows one of the servo outputs 0-3 to be enabled
- BYTE Channel
Range 0-3
CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
- STRING Filename
CardWriteByte
Appends a byte to the end of the currently open file
- BYTE Data
EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
- BYTE index
0=Left, 1=Right
SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
EncoderReset
Resets the motor encoder counters
LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
- BYTE State
0=Off 1=On
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
LCDClear
Clears the LCD
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud rate passed to the COM port to control the rate of data in bits per second.
Timeout Value
Value to specify what is returned when no incoming receive data is present.
Receive Timeout
Maximum amount of time to wait in milliseconds before returning the timeout value
Show Console
Simulations
