Component: FCD helper (Matrix Tools)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Category Matrix Tools
FCD helper component
A helper control to query the current Flowcode definition XML file.
GetStrListItem
Gets a list item from a string index and a textual name Suitable for writing to a property filter Newline is added
- STRING Index
- STRING Name
- STRING Return
GetIntListItem
Gets a list item from an integer and a textual name Suitable for writing to a property filter Newline is added
- UINT Index
- STRING Name
- STRING Return
Register
Registers a property to update when the FCD changes
[[File:]] - Dest
- STRING PropName
- STRING FCDPath
- UINT INdex
A zero based index of the path to find
- STRING IxAttr
- STRING NameAttr
GetPropertyList
Gets a filter list suitable for adding to a property Uses the [u]IxName[/u] as the index into the list Uses the [u]Text[/u] as the line to show in list-boxes
- STRING FCDPath
- UINT Index
- STRING IxName
- STRING Text
- STRING Return
GPS_Read_Over_Ground
[[File:]] - Return
GPS_Read_UTC_Date
- BYTE unit
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
GPS_HorizontalDilutionOfPrecision
[[File:]] - Return
FAT_ScanCurrentFolder
- UINT idx
- BYTE type
Scan type
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
GPS_Is_Data_Valid
FAT_AppendStringToFile
- STRING Text
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
FAT_OpenFolder
- STRING Folder
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
FAT_MoveToNextFileSector
- BYTE force
force next sector
FAT_ReadByteFromScan
- UINT idx
GPS_Read_NumberOfSatellites
FAT_ReadFileLength
FAT_CreateFile
- STRING Filename
MIAC_Module_PushData
- BYTE Data
GPS_Read_VerticalDilutionOfPrecision
[[File:]] - Return
FAT_WriteFileSector
GPS_Read_Altitude
[[File:]] - Return
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
FAT_ReadByteFromBuffer
- UINT address
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
FAT_WriteByteToBuffer
- UINT address
- BYTE data
FAT_ReadFileSector
FAT_DeleteFile
- STRING Filename
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
Initialize
Forces a software reset on the module
GPS_Read_UTC_Time
- BYTE unit
DigitalInput
Read the value of a terminal
- BYTE Terminal
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
- BYTE Duty
Duty cycle (8 bit value)
MI2C_Start
DigitalInput
- BYTE Terminal
UART_SendChar
- UINT Character
EncoderReset
Resets the motor encoder counters
LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
- BYTE State
0=Off 1=On
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
LCDClear
Clears the LCD
Simulations
