| Author
Matrix Ltd.
| Version
2.0
| Category
Comms: System
Modbus Slave component
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
Example master program to control the slave. The example reads the 8 switches connected to PortD. If the switch values change then the new value is send to the slave.
Modbus Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0-7 state to eight LEDs connected to PortD.
Modbus Slave Example
Master and Slave example using vNet
Example of communicating using Modbus Master and Slave using two instances of Flowcode and the vNet injector component.
ModbusMasterDemo
ModBusSlaveDemo
Addressing
| Data Type
Common name
Starting address
Ending Address
Flowcode Start Address
Flowcode End Address
| Modbus Coils
Bits, binary values, flags
00001
10000
0
9999
| Digital Inputs
Binary inputs
10001
30000
0
19999
| Analog Inputs
Binary inputs
30001
40000
0
9999
| Modbus Registers
Analog values, variables
40001
60000
0
19999
ReadHoldingRegister
| Reads the value of a single holding register.
- UINT
Address
| Coil Address
- UINT
SetCoil
| Sets the state of a single digital coil.
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
| Sets the state of a single digital input.
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
| Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
- UINT
SlaveAddress
ChangeFrameType
| Default frame type is the type set in the component properties.
- BYTE
Type
| 0 = Modbus RTU / 1 = Modbus ASCII
ReadCoils
| Reads the state of up to eight digital coils. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
| Coil Address Range 0 to (NumCoils - 1)
- BYTE
AddressCount
| Range 1-8
- BYTE
SetBaudRate
| Allows the Baud Rate to be controlled dynamically overriding the default rate specified by the Baud component property.
- BYTE
Rate
| 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200
SetHoldingRegister
| Sets the state of a single holding register.
- UINT
Address
| Coil Address
- UINT
Value
| Analogue Value range 0 - 65535
ReadAnalogInput
| Reads the value of a single analogue input.
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
| Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
- BYTE
ChangeBaud
| Changes the UART Baud rate. 1 = 1200 / 2 = 2400 / 3 = 4800 / 4 = 9600 / 5 = 19200 / 6 = 31250 7 = 38400 / 8 = 57600 / 9 = 115200
- BYTE
Baud
| The new baud rate (0=1200, 9=115200)
ReadDigitalInputs
| Reads the state of up to eight digital inputs. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
| Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
- BYTE
Index
| Range: 0-3
- UINT
SetAnalogInput
| Sets the state of a single analogue input.
- UINT
Address
| Coil Address
- UINT
Value
| Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
| Initialises the MIDI component and sets up the UART.
ReadAnalogInput
| Reads a single digital input.
- BYTE
- UINT
CommsBaud
| Sets the Baud rate of the alt communications channel
- BYTE
Baud
| Range: 0-7 : 0=1200 / 7=115200
LCDOptions
| Controls some of the LCD options
- BYTE
Foreground
| Range: 0-1
- BYTE
Background
| Range: 0-1
- BYTE
Transparent
| Range: 0-1
LCDVerbose
| Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BYTE
Mode
| Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
ReadDigitalInput
- BYTE
- BYTE
PWMConfig
| Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
- BYTE
| Range 0-1
- UINT
Period
| Range: 0-65535
- BYTE
Scaler
| Range: 0-3
PWMEnable
| Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
| Range 0-63 or 0b00000 to 0b111111
PWMDuty
| Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
- BYTE
| Range 0-5
- UINT
Duty
LCDCursor
| Sets the cursor position for the MIAC display
- BYTE
X
| Range: 0-21
- BYTE
Y
| Range: 0-4
WriteTran
| Allows a single transistor output to be switched on or off.
- BYTE
| Range 1-4
- BYTE
Value
| 0 = Off, 1 = On
LCDClear
| Clears the MIAC display
LCDClear
| Clears the LCD
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Baud Options
| Baud rate option selector
Bus
| Specifies the bus mode being used, RS232 allows you to connect a single master node to a single slave node. RS485 allows you to connect a single master node to multiple slave nodes.
Timeout
| Timeout in milliseconds used to dictate the maximum time to wait in milliseconds between bytes in a packet. Range: 1 - 255
Frame Type
| Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
| Maximum number of bytes the receive buffer can hold
Slave ID Bytes
| Number of bytes used when passing a slave ID, usually 1 but sometimes 2
Slave Address
Reply Delay
| Delay in micro seconds to wait before transmitting a reply
Maintain Stats
| Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
| A text label to appear on the Modbus panel object.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data API component on the Panel.
API
| Selects which API component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
Starting Address
| Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Starting Address
| Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Starting Address
| Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Starting Address
| Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
Simulations
