Component: Slider control (Advanced Shapes)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Advanced Shapes |
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications.
 Meters
Meters
|   | GetValue |
| Gets the current value of the slider. This will be within the range set by the SetRange macro. | |
| [[File:]] - | Return |
|   | SetValue |
| Set the current value of the slider. This will override any value set by using the mouse. | |
| [[File:]] - | Value |
| The value to set. | |
|  - VOID | Return |
|   | SetInteractive |
| Set whether the mouse can be used to change the slider value. | |
| [[File:]] - | Enable |
| Set true to allow clicks to set scale | |
|  - VOID | Return |
|   | ShowScale |
| Set whether graduated marking are shown along the length of the slider. | |
| [[File:]] - | Show |
| True to show scale, else false | |
|  - VOID | Return |
|   | SetRange |
| Set the minimum and maximum values that can be shown on the slider. | |
| [[File:]] - | Min |
| Min (start) value | |
| [[File:]] - | Max |
| Maximum (end) value | |
|  - VOID | Return |
|   | GetDeviceCount |
| Returns the number of devices found by the last ScanBus operation. | |
|  - BYTE | Return |
|   | Initialise |
| Sets up the 1-Wire output pin ready for communications. | |
|  - VOID | Return |
|   | GetDeviceCount |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | GetDeviceCount |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | SetAnalogInput |
| Sets the state of a single analogue input. | |
|  - UINT | Address |
| Coil Address | |
|  - UINT | Value |
| Analogue Value range 0 - 65535 | |
|  - VOID | Return |
|   | Initialise |
| Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0. | |
|  - VOID | Return |
|   | Initialise |
| Initialises the MIDI component and sets up the UART. | |
|  - VOID | Return |
|   | CommsBaud |
| Sets the Baud rate of the alt communications channel | |
|  - BYTE | Baud |
| Range: 0-7 : 0=1200 / 7=115200 | |
|  - VOID | Return |
|   | LCDOptions |
| Controls some of the LCD options | |
|  - BYTE | Foreground |
| Range: 0-1 | |
|  - BYTE | Background |
| Range: 0-1 | |
|  - BYTE | Transparent |
| Range: 0-1 | |
|  - VOID | Return |
|   | ReadDigitalInput |
| Reads a single digital input. | |
|  - BYTE | Channel |
|  - BYTE | Return |
|   | PWMDuty |
| Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535 | |
|  - BYTE | Channel |
| Range 0-5 | |
|  - UINT | Duty |
|  - VOID | Return |
|   | LCDCursor |
| Sets the cursor position for the MIAC display | |
|  - BYTE | X |
| Range: 0-21 | |
|  - BYTE | Y |
| Range: 0-4 | |
|  - VOID | Return |
|   | WriteTran |
| Allows a single transistor output to be switched on or off. | |
|  - BYTE | Channel |
| Range 1-4 | |
|  - BYTE | Value |
| 0 = Off, 1 = On | |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | LCDClear |
| Clears the MIAC display | |
|  - VOID | Return |
|   | LCDClear |
| Clears the LCD | |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Simulations |
