Component: Event Log (Runtime Tools)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Category Runtime Tools
Event Log component
A simulation component designed to create a simple log record of events in your SCADA system. Logs to a file and / or to a console tab including optional automated time stamp.
LogEvent
Allows an event string to be logged
- STRING LogString
GetTextLine
Gets the string data from a specific line in the console.
[[File:]] - Line
Line number, -1 for the last line.
- STRING Return
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
[[File:]] - Last
I2CStop
- BYTE Channel
WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to. Stores the parameters into ROM for later USB free setup.
- STRING SSID
Name of the network you wish to connect to
- STRING Password
ServoDisable
Disable a Servo output
- BYTE Channel
Range: 0-5
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
ServoEnable
Enable a Servo output
- BYTE Channel
Range: 0-5
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-5
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
IOSetOutputPin
- BYTE Pin
Range: 0-17
[[File:]] - State
Range: 0-1
ServoSetPosition8
Sets the position as an 8-bit value
- BYTE Channel
Range: 0-1
- BYTE Position
Range: 0-255
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active.
- STRING Return
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Prescaler
PWMSetDuty8
- BYTE Channel
Range: 0-1
- BYTE Duty
Range: 0-255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
LCDClear
Clears the MIAC display
LCDClear
Clears the LCD
Log To Console
Log To File
Include Timestamp
Controls if a timestamp is appended to the start of the log string. Yes: Add timestamp to log string No: Leave log string as is
Console Name
Clear On Init
Selects if the contents of the console are maintained or wiped on runtime start. Yes: Console is automatically cleared No: Console is maintained and appended
Log File
File to store the log data. Default: $(srcdir)log.txt $(srcdir) specifies the directory containing your Flowcode project file. log.txt specifies a file named log.txt If the file does not exist then it will be automatically created for you.
Clear On Init
Selects if the contents of the log file are maintained or wiped on runtime start. Yes: Log file is automatically cleared No: Log file is maintained and appended
TimeStamp
US Date Format
Specifies the format of the date string. No - "DD/MM/YY" Yes - "MM/DD/YY"
Simulations
