Component: Timed Event Trigger (Runtime Tools)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Category Runtime Tools
Timed Event Trigger component
Component that will check to see if a predetermined amount of time has passed. Useful for doing things on a regular basis, e.g. every minute or every hour.
Reset
Resets the countdown timer
SetTimePeriod
Sets the time period in seconds. Ideally this should only be called when the timer is not running. Automatically stops, resets and restarts the timer if already running.
- ULONG Time
Time period in units specified
- BYTE Units
0=Seconds, 1=Minutes, 2=Hours
Stop
Stops the countdown timer running
CheckTrigger
Checks the state of the trigger to determine if the allocated amount of time has passed. Returns true if amount of time has passed, otherwise returns false.
[[File:]] - Return
Start
Starts the countdown timer running. Automatically performs a reset if the event has already been triggered.
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
[[File:]] - Last
I2CStop
- BYTE Channel
WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to. Stores the parameters into ROM for later USB free setup.
- STRING SSID
Name of the network you wish to connect to
- STRING Password
ServoDisable
Disable a Servo output
- BYTE Channel
Range: 0-5
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
ServoEnable
Enable a Servo output
- BYTE Channel
Range: 0-5
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-5
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
IOSetOutputPin
- BYTE Pin
Range: 0-17
[[File:]] - State
Range: 0-1
ServoSetPosition8
Sets the position as an 8-bit value
- BYTE Channel
Range: 0-1
- BYTE Position
Range: 0-255
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active.
- STRING Return
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Prescaler
PWMSetDuty8
- BYTE Channel
Range: 0-1
- BYTE Duty
Range: 0-255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
LCDClear
Clears the MIAC display
LCDClear
Clears the LCD
Time Period Units
Units of time to wait for
Time Period Value
Number of time periods to wait before firing
Call a macro
Decides if a user macro wil be called when the event time period is over. No - requires the use of polling in your application by calling the CheckTrigger component macro. Yes - Automatically calls the selected user macro
Auto Reset
Yes: Automatically resets and restarts the timer when running and actioned. No: Waits for the user to restart the timer running by calling the Start macro.
Simulations
