Component: SPI Slave (Comms: Interface)
Author | Matrix Ltd |
Version | 1.0 |
Category | Comms: Interface |
SPI Slave component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in.
Simple Master program that sends an incrementing test value to the SPI bus as well as outputting the value onto LEDs.
Simple Slave program that collects the value sent by the master and outputs the value onto LEDs. Allows the master slave comms to be compared to check that everything is working correctly.
Another simple example to buffer incoming SPI bytes sent by the master and output these to the LCD.
SendChar |
General purpose SPI send byte macro | |
Char |
Data byte to send | |
Return |
GetChar |
General purpose SPI get byte macro | |
Return |
UnInitialise |
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O. | |
Return |
Initialise |
Activates the SPI peripheral and claims control over the I/O pins. | |
Return |
Disable_CS |
Outputs a high signal to the chip select pin to deselect the remote slave device. | |
Return |
GetChar |
Return |
UnInitialise |
Return |
Enable_CS |
Outputs a low signal to the chip select pin to select the remote slave device. | |
Return |
Initialise |
Return |
I2CStop |
Put the I2C Module into Stop mode | |
Channel |
Return |
SPIPrescaler |
Modify the speed of the SPI bus | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
Prescaler |
Range: 0-2 | |
Return |
PWMSetDuty |
Sets the duty for the PWM output | |
Channel |
Range: 0-5 | |
Duty |
Return |
ADCSample10 |
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
ADCChannel |
Range: 0-12 | |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-29 | |
[[File:]] - | State |
Range: 0-1 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
DataOut |
[[File:]] - | Return |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
PWMSetPrescaler |
Sets the prescaler for the PWM output | |
Channel |
Prescaler |
Period |
Return |
PWMEnable |
Enable a PWM output | |
Channel |
Range: 0-1 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
IOSetOutputPin |
Pin |
Range: 0-29 | |
Range: 0-1 | |
Return |
UARTReceive |
Channel |
Return |
OneWireScanBus |
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
Channel |
Return |
SPIInitialise |
Channel |
Return |
OneWireReceiveByte |
Receives a byte from the one wire bus a bit at a time | |
Channel |
Return |
I2CSend |
Channel |
DataOut |
UARTSend |
Channel |
Data |
Return |
OneWireGetDeviceCount |
Returns the number of devices found by the last ScanBus operation. | |
Channel |
Return |
PWMSetPrescaler |
Channel |
Range: 0 - 11 | |
Prescaler |
Period |
Return |
PWMEnable |
Channel |
Range: 0-11 | |
Return |
Initialise |
Return |
Initialise |
Return |
